fix heater hose threads in a aluminum intake #2561016
10/08/18 06:33 PM
10/08/18 06:33 PM
md
mopars4ever Offline OP
md
Like a dummy, I tapped out the threads for the heater hose fitting in my small block aluminum intake with the wrong tap. What would be the best way to fix? The fitting now screws all the way down with no interference fit and I`m afraid it will leak even with pipe tape.
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561017
10/08/18 06:37 PM
10/08/18 06:37 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Is it flat enough that you could consider thread sealant and a copper washer?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561018
10/08/18 06:46 PM
10/08/18 06:46 PM
md
md
Not sure I will have to take another look at it.
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561021
10/08/18 06:57 PM
10/08/18 06:57 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
You can partially weld it up then drill and re-tap with an NPT tap. Or just try and use the next largest NPT thread tap and do something unique with the hose fitting.
1972 Dodge Challenger
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561024
10/08/18 06:59 PM
10/08/18 06:59 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Buy a brass reducer bushing at the hardware store with the correct inner & outer pipe threads.
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561110
10/08/18 10:11 PM
10/08/18 10:11 PM
Maryland
MoparMike1974 Offline
Maryland
Sounds like he might have used a regular thread tap instead of NPT.
If there is enough meat on the intake you could take it to the next size NPT and install a brass reducer bushing to get back to the right size.
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561186
10/09/18 12:14 AM
10/09/18 12:14 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Almost sounds to me like he used an NPT tap but went too far on the taper and the fitting might not start to bite until it's bottomed out.
2020 RAM 1500
Re: fix heater hose threads in a aluminum intake [Re: GoodysGotaCuda] #2561218
10/09/18 01:20 AM
10/09/18 01:20 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
some years ago i used a epoxy type repair where you put it on the threads screwed it in then unscrewed the fitting and waited for it to setup,i used it on a stripped ford brake caliper,i cant remember the exact name ,but it was something like thread renew,etc,etc
it worked great seems like you had to put something on the good threads first so they would release after it was screwed it before it cured,its been a few yrs back ,my memory is pretty spotty in my old age
my ladder of success is missing some rungs
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561226
10/09/18 01:41 AM
10/09/18 01:41 AM
what about JB welding it in there permanently? I've JB welded fittings into the cooling system for cooling routing mods & No issues.
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561310
10/09/18 10:20 AM
10/09/18 10:20 AM
md
md
Yes, I used a regular tap. The epoxy will probably work and I will look into it. I will look into the brass bushing idea too. I have to dig the intake back out. After I messed it up I put it away and now I think I`m going to try and use it. Thanks for the helps guys.
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561486
10/09/18 04:54 PM
10/09/18 04:54 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
They sell NPT thread repair kit's,
https://www.mscdirect.com/browse/tnpla/94204013?cid=ppc-google-New+-+Threading+-+PLA_seJ7a6JRI___164110843911_c_S&mkwid=seJ7a6JRI|dc&pcrid=164110843911&rd=k&product_id=94204013&gclid=EAIaIQobChMI_M2v04P63QIVEdbACh3AJAK6EAQYAiABEgLNY_D_BwE
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561547
10/09/18 07:10 PM
10/09/18 07:10 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I'd just try to in weld the fitting in place
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561554
10/09/18 07:20 PM
10/09/18 07:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Welding a steel fitting into an aluminum intake would not work very well.....
Re: fix heater hose threads in a aluminum intake [Re: mopars4ever] #2561644
10/09/18 10:44 PM
10/09/18 10:44 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
True, but they make aluminum ones too smile
Re: fix heater hose threads in a aluminum intake [Re: DrCharles] #2562102
10/10/18 08:03 PM
10/10/18 08:03 PM
JB weld. NPT common plumbing iron fittings into alum tcover. solid as a rock.
Re: fix heater hose threads in a aluminum intake [Re: RapidRobert] #2562111
10/10/18 08:23 PM
10/10/18 08:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Please don't use black iron fittings on your mopar small block. You make us all look like hillbillys. IMO eek down
Nothing wrong with mopar cooling systems, so you don't have to "make it better"
Re: fix heater hose threads in a aluminum intake [Re: Challenger 1] #2562160
10/10/18 10:01 PM
10/10/18 10:01 PM
This will be out on the dirt track so it'll all be good. The hood will not be popped unless I win & get teched.
Re: fix heater hose threads in a aluminum intake [Re: RapidRobert] #2562171
10/10/18 10:17 PM
10/10/18 10:17 PM
Cincinnati, Ohio
Cincinnati, Ohio
Aren't worried about weight? Even worse if your going to use it racing IMO. Sorry.
Re: fix heater hose threads in a aluminum intake [Re: Challenger 1] #2562245
10/11/18 01:17 AM
10/11/18 01:17 AM
Actually that is a VERY valid point.
Re: fix heater hose threads in a aluminum intake [Re: RapidRobert] #2562408
10/11/18 12:59 PM
10/11/18 12:59 PM
moparx Offline
moparx  Offline
RR, why not a short chunk of heater hose, rather than all those fittings ?
beer
