1957/58/59 Dodge/Plymouth leaf springs
#2560075
10/06/18 08:52 PM
10/06/18 08:52 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Well, I measured and looked. My 58 Dodge rear leaf springs have 20" front segments and 35" rear segments, 55" overall length. Unless I'm wrong they are A body spring dimensions. Exactly. I've heard to run 5 leaf A body springs....
Anybody have any useful first hand advice or tips? Thanks
CrAzYMoPaRGuY
Re: 1957/58/59 Dodge/Plymouth leaf springs
[Re: CrAzYMoPaRGuY]
#2560462
10/07/18 07:13 PM
10/07/18 07:13 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'62-'63 B-bodies have the same segment lengths and might be a better choice for weight-carrying ability.
[Re: John_Kunkel]
#2560693
10/08/18 04:54 AM
10/08/18 04:54 AM
CrAzYMoPaRGuY
Canada
'62-'63 B-bodies have the same segment lengths and might be a better choice for weight-carrying ability. You are figuring the rear of the 58 considerably heavier than most A bodies I assume?
CrAzYMoPaRGuY
[Re: 5280Dart]
#2562764
10/12/18 04:07 AM
10/12/18 04:07 AM
CrAzYMoPaRGuY
Canada
You are correct, the A-body spring dimensions are the same. So much so, I run caltrac monoleaf springs and bars for an A-body in my 1957 plymouth. ... Perfect. lol How do you like how it sits? Do you think a set of A body springs 5 leafs per side would dit a little too high or should be ok? Any pics?
CrAzYMoPaRGuY
[Re: poorboy]
#2562765
10/12/18 04:09 AM
10/12/18 04:09 AM
CrAzYMoPaRGuY
Canada
According to the standard catalog of Chrysler, 1924-1990: A 58 Dodge Coronet 2 door sedan had a shipping weight of 3505lbs. A 58 Plymouth Fury 2 door club sedan had a shipping weight of 3240 lbs - 3370 lbs. : A 4 door Fury sedan at 3255 lbs - 3430 lbs
The same book lists a 71 Duster with a shipping weight of 2825 lbs - 2920 lbs A 71 340 Duster at 3140 lbs. : A 4 door Valiant at 2835 lbs - 2935 lbs
The book lists a 63 Belvedere 2 door sedan at 3000 lbs - 3215 lbs A 2 door ht at 3025 lbs - 3190 lbs : A 4 door sedan at 3020 lbs
The book lists a 69 383 Road Runner at 3435 lbs coupe and 3450 lbs HT
Looks to me the A body weighs about the same as the 63 B body and both are a little light, but the 69 B Body's are closer in weight to the 58 cars. Gene If strictly overall weight was the only factor this would be easy! I think the 57/58/59 Plymouths and Dodges are very close to an A body rear spring with 5 leafs per side, but MIGHT sit a touch high....
CrAzYMoPaRGuY
[Re: Handygun]
#2565217
10/17/18 02:49 AM
10/17/18 02:49 AM
CrAzYMoPaRGuY
Canada
My 58 suburban was about 4250, real curb wt. With the 392/518 a lot of that weight was upfront but that's a lot heavier than a a-body. lol When I'm finished I'll weigh and post the weight.
CrAzYMoPaRGuY
[Re: poorboy]
#2565219
10/17/18 02:53 AM
10/17/18 02:53 AM
CrAzYMoPaRGuY
Canada
One would expect a wagon to be heavier then a 2 door coupe or sedan. 4250 is in the range of a C body or a 70s 4x4 pickup.
Is your 392 an old Hemi or a new Hemi? Gene 3750 curb weight with a 6!!
CrAzYMoPaRGuY
[Re: 5280Dart]
#2567128
10/21/18 12:22 AM
10/21/18 12:22 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
You are correct, the A-body spring dimensions are the same. So much so, I run caltrac monoleaf springs and bars for an A-body in my 1957 plymouth. ... Combination of A body super stock, and original springs in my '58 Sport suburban.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: CrAzYMoPaRGuY]
#2567168
10/21/18 02:40 AM
10/21/18 02:40 AM
CrAzYMoPaRGuY
Canada
I just ordered P3412002 and P3412003 SuperStock springs. Will see how it goes!!!!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2569929
10/26/18 08:43 PM
10/26/18 08:43 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I just ordered P3412002 and P3412003 SuperStock springs. Will see how it goes!!!! you need to press out the metal sleeve on your factory bushings, and press it into the metal sleeve on the super stock springs. the bolt diameters are different.
[Re: Spaceman Spiff]
#2570061
10/27/18 01:22 AM
10/27/18 01:22 AM
CrAzYMoPaRGuY
Canada
I just ordered P3412002 and P3412003 SuperStock springs. Will see how it goes!!!! you need to press out the metal sleeve on your factory bushings, and press it into the metal sleeve on the super stock springs. the bolt diameters are different. Ha! Never heard that, thanks for the warning!!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2570500
10/28/18 08:19 AM
10/28/18 08:19 AM
Posts: 1,511 AZ
Mike P
AZ
I used super stock springs on the 57 Dodge I built 20 years ago and I do remember I had to drill the front spring perches for a larger bolt.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: moparx]
#2572889
11/02/18 03:51 AM
11/02/18 03:51 AM
CrAzYMoPaRGuY
Canada
if the super stock springs have a larger diameter bolt bushing than your original springs, i would drill out your original spring hanger to fit the bolt size of the SS springs. Yup! I'll use A body bolts for sure! Thanks guys!! Got one spring already, second coming this weekend
CrAzYMoPaRGuY
[Re: poorboy]
#2586467
12/03/18 05:31 AM
12/03/18 05:31 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
Looks to me the A body weighs about the same as the 63 B body and both are a little light, but the 69 B Body's are closer in weight to the 58 cars. Gene That book is wrong on the original shipping weights of the 1963 Plymouth Belvederes 2 door sedans, way to light I raced a original 1963 Plymouth M.W. 415 HP 2 door sedan with the original factory carpet, heater and radio delete option, the NHRA minimum weight for that car back in the mid 1970 was 3320 Lbs. with out the driver I had to remove the heater to get it down to that weight with a half of tank of gasoline Maybe the aluminum front end cars could have been near those weight but not the OEM all steel cars I also owned and raced a M.W. 1963 Belvedere 2 door hardtop, it weighed more the sedan did I've owned and race more than one A body also, they are a lot lighter than any of the B body where My last pump gas BB 1971 duster weighed 3450 Lbs. with me in it with a full tank of gas, I weighed around 270 Lbs. with all the race gear on in that car at the tracks. That car had a fibrgelas race weight hood and front bumper, extra insulation under the heavy duty good carpet, I wasn't trying to make that car a lightweight do to wanting to race it on the streets of L.A for money I owned a 1959 Dodge Coronet 326 C.I.V8 Powerflyte 2 door hardtop also, no way it was as light as the later B bodies where I'm thinking that car was nearer to 4000 Lbs. empty than nearer to 3500 Lbs.
[Re: Cab_Burge]
#2586904
12/04/18 02:57 AM
12/04/18 02:57 AM
CrAzYMoPaRGuY
Canada
I owned a 1959 Dodge Coronet 326 C.I.V8 Powerflyte 2 door hardtop also, no way it was as light as the later B bodies where I'm thinking that car was nearer to 4000 Lbs. empty than nearer to 3500 Lbs. My brother had a 1957 Plymouth Savoy four door with a 301 wideblock 2 speed auto. We took it to a scale, it weighed 3530 no driver...
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2586985
12/04/18 12:42 PM
12/04/18 12:42 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I owned a 1959 Dodge Coronet 326 C.I.V8 Powerflyte 2 door hardtop also, no way it was as light as the later B bodies where I'm thinking that car was nearer to 4000 Lbs. empty than nearer to 3500 Lbs. My brother had a 1957 Plymouth Savoy four door with a 301 wideblock 2 speed auto. We took it to a scale, it weighed 3530 no driver... The dodge is a bigger car. 4 more inches of wheelbase.
#2587010
12/04/18 01:44 PM
12/04/18 01:44 PM
Posts: 1,826 South Bend
John Brown
South Bend
I owned a 1959 Dodge Coronet 326 C.I.V8 Powerflyte 2 door hardtop also, no way it was as light as the later B bodies where I'm thinking that car was nearer to 4000 Lbs. empty than nearer to 3500 Lbs. My brother had a 1957 Plymouth Savoy four door with a 301 wideblock 2 speed auto. We took it to a scale, it weighed 3530 no driver... The dodge is a bigger car. 4 more inches of wheelbase. My NHRA Stock Car Classification Guide shows a 1959 Coronet 326 / 255 horsepower two door hardtop with auto as having a weight break of 13.60. That puts shipping weight at 3468. NHRAracer.com only goes back to 1960 on their internet guide so I had to dig out my old hard copy dated 1969.
#2587029
12/04/18 02:32 PM
12/04/18 02:32 PM
CrAzYMoPaRGuY
Canada
I gotta measure my 1958 Dodge Regent. It's a Canadian Dodge.... a Plodge. Dodge front end but Plymouth from the firewall back. I assume it's a shorter Plymouth wheelbase......?
CrAzYMoPaRGuY
[Re: BeEtLeJuIcE !]
#2587228
12/04/18 10:48 PM
12/04/18 10:48 PM
CrAzYMoPaRGuY
Canada
Plodge ... ONLY available from our good friends NORTH OF THE BORDER from miniVancouverLand !! Hey!!!! We get Chevrolet powered 1960's Pontiacs too!!!! Nothing weird up here. No no.....
CrAzYMoPaRGuY
[Re: John Brown]
#2587253
12/04/18 11:29 PM
12/04/18 11:29 PM
Cab_Burge
I owned and drove a bunch of early, pre 1960s Dodge, Plymouth and Chrysler two door hardtops and one 1959 Plymouth two door sedan. I had to weigh the 1960 Dodge Phoenix that was missing the rear seat, radio, heater and all the floor mats and interior insulation to race it at a race at the old airport in Indio, CA. It weighed 4060 Lbs. with a half of tank of fuel with all iron stroker 383 motor with the OEM inline dual quads with a cheap set of Tri Y headers and no exhaust system on it and no driver. It ran high 12. ET in B/MP back in 1969 on a set of 750x14 6 inch wide tread width J.C Penney cheater slicks, those tires wiggle around a bunch on the other end when I let off I flat towed it to and from the races with a 1957 Chrysler 300 C car I should have kept a bunch of those cars, but I didn't All of those pre 1962 cars had full steel frames and no weight saving aluminum parts on them until 1963 When Mopar got deep into drag racing to sell more cars
