Re: 318 4bbl intake options?
[Re: V194]
#2559143
10/04/18 11:46 PM
10/04/18 11:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just run the intake you have you will not notice anything. I ran that exact combo for years on my 87 Diplomat. All this runner mismatch hype is nothing but turd polishing on a relatively stock 318. You'd notice more putting in a 340 cam and that would be a better place to spend your money.
[Re: Supercuda]
#2559145
10/04/18 11:49 PM
10/04/18 11:49 PM
Posts: 3,110 SC
V194
SC
Just run the intake you have you will not notice anything. I ran that exact combo for years on my 87 Diplomat. All this runner mismatch hype is nothing but turd polishing on a relatively stock 318. You'd notice more putting in a 340 cam and that would be a better place to spend your money. Mild cam, headers and MP ignition installed years ago. Im looking to confirm if any aftermarket manifolds match the 302 port.
[Re: V194]
#2559154
10/04/18 11:58 PM
10/04/18 11:58 PM
Supercuda
About to go away
About to go away
up yours
I never measured the port int he 302 heads so I dunno, it's real narrow around the pushrod bulge
[Re: V194]
#2559242
10/05/18 03:11 AM
10/05/18 03:11 AM
Posts: 4,848 Memphis
HemiRick
Memphis
The best manifold for a 318 is one w 318 sized ports....The only one ever made was by Edelbrock in the old days....model D4B it has GREAT throttle response and is the BEST manifold I've used on a 318 bar none.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2559633
10/05/18 08:40 PM
10/05/18 08:40 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
The Weiand Stealth (or Action Plus for spreadbore carbs) is nearly an identical match to the LD4B. Ports on the one I have had a LOT of variation in size but most were closer to the 318 port opening than the larger 340/360.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: V194]
#2559649
10/05/18 09:26 PM
10/05/18 09:26 PM
Supercuda
About to go away
About to go away
up yours
You are wasting your time.
The pushrod pinch is substantially smaller than the port entry so who really cares if the intake and head port dimensions match.
[Re: V194]
#2559767
10/06/18 09:37 AM
10/06/18 09:37 AM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
The old Street master had 318 ports also.Have one I bought used and never did use as my son sold his truck.Not the greatest for performance but IIRC they do run decent and are cheap.Rocky
Chrysler Firepower
