Page 6 of 8 1 2 3 4 5 6 7 8
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559125
10/04/18 11:08 PM
10/04/18 11:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Those of you thinking fuel issue, or cam timing I think miss one crucial fact. His video is with no load on it.
I cannot imagine a fueling issue that would cause it to do this unless it was massively rich and it'd be blowing great clouds of black smoke.
I cannot imagine a cam timing issue that would let it run at all and do this.
It almost has to be ignition.
Don't be the exception.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559148
10/04/18 11:51 PM
10/04/18 11:51 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There was a thread on here a couple years ago about a car going super lean in the upper rpm range. I can't recall if it was laying down like this one though. It turned out to be a fuel line sucking shut back by the tank.
This one still seems like valve springs or lifters though.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: Guitar Jones] #2559173
10/05/18 12:34 AM
10/05/18 12:34 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Originally Posted By Guitar Jones
I'm qualified, and infinitely more qualified than you Mr. Construction worker.
Well, that was pretty rude.
I can degree a cam...Can you build a house? Lay out a frame? Calculate roof pitch and cut rafters that fit? I would be very surprised to hear that you can but since this is a car forum, lets focus on that instead of insulting another mans trade.
You made it clear that you thought that degreeing a cam is pointless. Maybe it is to YOU but if nothing else, it can rule out an area that allows you to focus elsewhere.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: Kern Dog] #2559187
10/05/18 12:59 AM
10/05/18 12:59 AM
Washington
madscientist Offline
Washington
Don't let guitar dude get to you. He was a line mechanic and not an engine builder or a machinist and they ain't the same thing.
IDGAF if Chrysler, or GM or ford or anyone else lines the cam dot to dot. The factory didn't give a single [censored] how they ran when they left the factory. They didn't care. It's quick and dirty to dot to dot and it shows lack of experience.
To the OP. I don't really care what is wrong with your engine. What I'm saying is to do the job correctly, and eliminating potential problems you need to STOP and degree the cam.
It's that simple. You can be a keyboard builder who cuts corners, or, you can do the [censored] correctly.
Degree the cam.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: madscientist] #2559212
10/05/18 01:54 AM
10/05/18 01:54 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
Any chance there are weak grounds in the system?
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: blown340] #2559260
10/05/18 05:34 AM
10/05/18 05:34 AM
Guitar Jones Online laugh2
There is a huge chance of this. It's probably the single most frequent problem seen in these old trucks.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559278
10/05/18 09:16 AM
10/05/18 09:16 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Truck is running well now as it appears to have been a combination of things.
Thanks for the help and drama!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559284
10/05/18 09:41 AM
10/05/18 09:41 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I saw a mild 318 do this, would hit a wall at 3,500 and everyone was telling the guy valve springs but was I talking to some chiivy guys that had told me about one of those great 350 engines which did the same thing and it had AC plugs so we checked his plugs and were AC's. Problem was solved with a set of autolite copper tips!
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559295
10/05/18 10:15 AM
10/05/18 10:15 AM
Soo, you are just going to keep it to yourself?
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559298
10/05/18 10:25 AM
10/05/18 10:25 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Tick Tick Tick
That's more drama until
Let the truth bee told !!!
Lol
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559305
10/05/18 10:39 AM
10/05/18 10:39 AM
DemonDuster Offline
DemonDuster  Offline
Hit a wall ? gotta hurt... Baad Ground volt drop, solution buy a mustang. Junk dat cam too an decree it already, Kongratz, I luv draamma. (Glad you got it figured out.)
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: Guitar Jones] #2559309
10/05/18 10:52 AM
10/05/18 10:52 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I degreed the cam and now my exhaust smells like fresh baked cookies and unicorns lead the way everywhere I go. popcorn
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559312
10/05/18 10:56 AM
10/05/18 10:56 AM
haha
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: Guitar Jones] #2559315
10/05/18 11:11 AM
10/05/18 11:11 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Filled the gas tank, corrected not having full throttle, cleaned the batterery terminals, ohhhh and he readjusted the rev limiter. LOL.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: pittsburghracer] #2559324
10/05/18 11:31 AM
10/05/18 11:31 AM
So are you telling me that degreeing the cam is not going to give me the desired fresh baked cookie and unicorn effect?!?
I'm so disappointed. whiney
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559333
10/05/18 11:50 AM
10/05/18 11:50 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That’s the kind of post I’d expect to see if one were a little embarrassed about what the problem actually was.
And....... doesn’t help the next guy who might find themselves in the same situation.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559374
10/05/18 01:10 PM
10/05/18 01:10 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yep ^, so was it the tachometer???
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2559380
10/05/18 01:19 PM
10/05/18 01:19 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I replace a fuel pump on a mustang with a 4 cylinder because it shutoff and wasn’t getting fuel. With the new pump still wasn’t getting fuel!!!!! Then I noticed the cam sprocket wasn’t turning. Dohhhh! Broken timing belt. Had a friend try to start his truck for two hours called me and I came over and found the rotor sitting on the core support. I could go on and on and on! If you haven’t screwed up your really haven’t done much.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: FurryStump] #2559418
10/05/18 02:14 PM
10/05/18 02:14 PM
moparx Offline
moparx  Offline
and the answer is ???????????
beer
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: moparx] #2559460
10/05/18 03:15 PM
10/05/18 03:15 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Carb to small.... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
