Pics of air filters on Dominators & height #255806
03/16/09 02:52 PM
03/16/09 02:52 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
I am getting some intake work done on my Indy intake part of the new combo will be a 1 inch, 4 hole spacer. I am limited on hood clearance. If you guys could post pics and height dimensions from round gasket surface to top of stud or air filter please. It is a dominator. Thanks!!
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Pics of air filters on Dominators & height [Re: 67HEMI] #255807
03/16/09 03:31 PM
03/16/09 03:31 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
I don't know if you want to build one like this but ....... here is a thread I started.
https://board.moparts.org/ubbthreads/show...e=0#Post5095393
I too had height issues and this set up with the 3" K&N filter is about 2-1/2" above the dominator. Everything I found on Summit's site was 3-3/4" or higher which would have maxed me out. You could probably build something similar with one of the fiberglass re-pop bases if you wanted and don't have a steel base.
Re: Pics of air filters on Dominators & height [Re: Keith Richards] #255808
03/17/09 09:01 AM
03/17/09 09:01 AM
67HEMI Offline OP
67HEMI  Offline OP
That would work IF I had an air grabber setup That is a good idea though. Once I get my intake back I will do some measuring and see exactly how much clearance I have.
