#2554847 - 09/25/18 10:44 PM What crank pulley do I need?
gsmopar Offline
Loc: Arizona, USA
Apparently ATI Super Dapners are a bit thicker than the generic SFI balancer I ran on my wedge.
From the ATI website; I appear to have 917122E which uses OE style timing cover, steel case, and "Not an OEM replacement for stock pulley location." I can't seem to find pulley recommendations on their site. Has anyone run into this before?
Edited by gsmopar (09/26/18 10:44 PM)
#2554848 - 09/25/18 10:46 PM Re: What crank pulley do I neet? [Re: gsmopar]
AndyF Offline
Loc: Oregon
Doty makes shorter pulleys. That is what I recommend for my race alternator kits: http://arengineering.com/products/motorplate-kit-powermaster/
#2554858 - 09/25/18 10:57 PM Re: What crank pulley do I neet? [Re: AndyF]
gsmopar Offline
Loc: Arizona, USA
This one (and I'm using your motorplate)?
https://www.dotymi.com/mopar-crankshaft-pulleys/14-crankshaft-pulley-mopar-chevy-.html
#2554933 - 09/26/18 08:28 AM Re: What crank pulley do I neet? [Re: gsmopar]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Just space the alternator out a lil bit.
CHIP
'70 hemicuda street car...8.91 at 150.5 mph w/ 4.10s, 8.97 at 152.5 mph w/ 3.54s so far
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
#2555039 - 09/26/18 12:30 PM Re: What crank pulley do I neet? [Re: gsmopar]
Superfreak Offline
Loc: the great wet north
How thick is that motor plate?
"Too much to do and not enough time to do it"
#2555124 - 09/26/18 04:14 PM Re: What crank pulley do I neet? [Re: Superfreak]
gsmopar Offline
Loc: Arizona, USA
1/2 in.
#2555161 - 09/26/18 05:26 PM Re: What crank pulley do I neet? [Re: gsmopar]
Loc: Bend,OR USA
I have had the ATI hubs shortened on the crankshaft side in the past to align the pulleys work scope
How about using a 426 street hemi crank pulley also first? scope
#2555188 - 09/26/18 06:33 PM Re: What crank pulley do I neet? [Re: gsmopar]
MR_P_BODY Offline
Loc: Romeo MI
If using a stock style water pump make sure that
lines up first.. then you can add spacers/washers
to line up the alt.. no reason to make this difficult
wave
Edited by MR_P_BODY (09/26/18 06:35 PM)
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#2555197 - 09/26/18 06:46 PM Re: What crank pulley do I neet? [Re: gsmopar]
gsmopar Offline
Loc: Arizona, USA
Running a drop in electric water pump. Thanks for the replies!
#2555201 - 09/26/18 06:55 PM Re: What crank pulley do I neet? [Re: gsmopar]
MR_P_BODY Offline
Loc: Romeo MI
So in that case you just need to add a spacer
or a few washers to get the alt lined up.. very
simple.. you dont even need to spend the big
bucks for a trick pulley
wave
CAR IS FOR SALE
#2555224 - 09/26/18 07:43 PM Re: What crank pulley do I neet? [Re: MR_P_BODY]
gsmopar Offline
Loc: Arizona, USA
wave
I’m concerned about space if the crank pulley is spaced that far out. Just curious what pulley others are using with this balancer. I’m going with Andyf’s suggestion.
#2555497 - 09/27/18 10:12 AM Re: What crank pulley do I neet? [Re: gsmopar]
J_BODY Offline
Loc: aZLiViN
I prefer things “tighter” to the engine so I can understand where you’re coming from... the Doty mount on my RB, and small 1 wire alt, I ran his flat pulley on my dampner.
#2555642 - 09/27/18 05:00 PM Re: What crank pulley do I neet? [Re: gsmopar]
shorthorse Offline
Loc: Ohio
#2555721 - 09/27/18 08:09 PM Re: What crank pulley do I neet? [Re: gsmopar]
MR_P_BODY Offline
Loc: Romeo MI
wave
Do you own the crank pulley you show on the
engine now.. is so all you would do is move the
alt out about 3/16".. I build my own pulleys
so it easy for me.. but if you run just the
crank and alt you might be able to cut the
outer pulley off(but maybe not)
wave
CAR IS FOR SALE
#2555744 - 09/27/18 09:15 PM Re: What crank pulley do I need? [Re: gsmopar]
AndyF Offline
Loc: Oregon
Maybe cut down the pulley you have on the engine now? If it is solid you can put it in a lathe and just shave 1/2 inch or whatever you need off the base.
#2555797 - 09/27/18 10:54 PM Re: What crank pulley do I need? [Re: gsmopar]
gsmopar Offline
Loc: Arizona, USA
The current pulley is hollow. It's a March 33% under driven with dual grooves. My DMI bracket has all of the supplied spacers plus a few washers to get the alternator where it is. I no longer need the second groove of this pulley (ditched the P-Steering) and someone (or me) will probably need this for another project. I'm not going to attempt to modify the pulley nor further space out the alternator. I don't mind buying a new pulley. Just wanted to know what others are using with this balancer. Doty pulley ordered yesterday. Thanks!
#2556211 - 09/29/18 08:32 AM Re: What crank pulley do I need? [Re: gsmopar]
ZIPPY Offline
Loc: S.E. Michigan
Glad you got it sorted out.
For info purposes I've been using an obscure Moroso pulley on mine. They don't make it anymore so it's better to find something more readily available.
11.0 @ 123 in street trim
This isn't the first time I put something together that only made sense to me....
#2556214 - 09/29/18 08:47 AM Re: What crank pulley do I need? [Re: ZIPPY]
sgcuda Offline
Loc: Charlotte, North Carolina
I've been using the Moroso cast pulleys, myself. You can still find them for sale. They have a solid base, and had mine cut down for proper alignment. Just get shorter Allen bolts.
#2556217 - 09/29/18 09:02 AM Re: What crank pulley do I need? [Re: sgcuda]
ZIPPY Offline
Loc: S.E. Michigan
Yeah good point, they do still sell the cast ones. The reference I made was towards the anodized billet one on the left..They still sell that style for brand x but discontinued them for the Mopar applications. I really like that they're solid and can be machined.
25,743 Registered Members
193,015 Topics
throttle body question
by dickdale
02/22/19 05:27 AM
I'm back and I survived ! and I have a new Mopar!
by NAS Backyard
02/22/19 12:36 AM
Largest Tire on cop car rim to fit a 67 Monaco ?
by NAS Backyard
02/22/19 12:15 AM
1985 Dodge W150
by Neil
02/21/19 10:51 PM
