771 horse stock stroke 360 motor, pump gas
#2554523
09/25/18 03:37 PM
09/25/18 03:37 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
Local engine builder is taking this motor to Charlotte on 4th Oct for Race Engine Challenge competition 11.95 compression, runs on pump gas. Stock 360 Magnum block, cast tunnel ram. Victor heads he did with 2.175 intake valves. Guess it will be live streamed, that will be fun to watch. Mopar Muscle feature on build upcoming.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas
[Re: B3422W5]
#2554577
09/25/18 04:57 PM
09/25/18 04:57 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Impressive!!
I don’t remember how the scoring will be done compared to the EM contests.
[Re: B3422W5]
#2554627
09/25/18 06:14 PM
09/25/18 06:14 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Having dealt with 360s in the past, I'll just say, ummmmm...OK. Power adder?
[Re: B3422W5]
#2554634
09/25/18 06:23 PM
09/25/18 06:23 PM
fast68plymouth
So. Burlington, Vt.
Looks like the gist of the scoring is best average hp over three runs, 4000-7500rpm, times 1000, divided by cubic inch.
[Re: CMcAllister]
#2554645
09/25/18 06:34 PM
09/25/18 06:34 PM
B3422W5
Portage,michigan
Having dealt with 360s in the past, I'll just say, ummmmm...OK. Power adder? No power adder. Motor will be at the competition week from Thursday, we will get to see it run. Block is 100 over, 3/4 filled. He was surprised how much meat remained when he sonic checked it. Made this number at 7500 rpm. 775 lift roller. Has around 55 pulls on it sorting it out Jack Barna..... Valley performance and Machine
[Re: AndyF]
#2554685
09/25/18 07:34 PM
09/25/18 07:34 PM
B3422W5
Portage,michigan
That is a lot of steam for a stock stroke 360, even with the big bore size. It took me a few years to make 750+ hp with my pump gas 470 engine and some people didn't believe those numbers.
Of course, the NASCAR boys make even more power with fewer inches so it just all depends on how good the heads are. Nice thing is we will all get to see it at a neutral setting competition. Hope he kicks some butt
[Re: B3422W5]
#2554688
09/25/18 07:36 PM
09/25/18 07:36 PM
fast68plymouth
So. Burlington, Vt.
2.03 hp/ci....... pretty stout.
[Re: B3422W5]
#2554692
09/25/18 07:43 PM
09/25/18 07:43 PM
B3422W5
Portage,michigan
Picture of the engine under “ view blog” on Valley performance and machines website. Purdy
[Re: fbs63]
#2554697
09/25/18 07:54 PM
09/25/18 07:54 PM
B3422W5
Portage,michigan
I would love to see an engine masters where they dyno test then put the engine in a car. The power numbers are always impressive but I cant remember hearing of a quick car with one of these engines. I bought an enginemasters 318 motor off one off the competitors from a few years back( in fact one of his partners, Randy Malik i see is in this competition) installed it in my car, and it ran nearly exactly what i figured it would run based on its pulls at enginemasters. You can google the build/ engine......... LA Confidential Mopar....... will pull it up. Beat on it Track and street for three years till selling the car. Mid 11’s at 3400 pounds with flat hood. Another member on here bought a motor Brett Miller built for enginemasters, it too puts down the number at the track it should. He has a small pickup, is from down South posts on here often, his screen name eludes me, but he’s on here all the time So there are two real world examples
[Re: WO23Coronet]
#2554705
09/25/18 08:09 PM
09/25/18 08:09 PM
fast68plymouth
So. Burlington, Vt.
I know there's formulas for this but is 770 hp possible at 7500 rpm with only 378"? I know that much hp is doable at the cu in for sure, I just thought it would be at a higher rpm, have to be some pretty stout volumetric efficiency. Before the rules changes that killed the 358” Cup motors by about 200hp, when they were solidly well over 900hp....... I’m sure they were also solidly over 770hp@7500 rpm.
[Re: B3422W5]
#2554730
09/25/18 09:16 PM
09/25/18 09:16 PM
Posts: 4,206 New York
polyspheric
New York
At that lift, the rocker arm is pointing nearly up & down every rotation (this is a function of lever length vs. lift, nothing to do with ratio). Life expectancy...?
Boffin Emeritus
[Re: polyspheric]
#2554739
09/25/18 09:32 PM
09/25/18 09:32 PM
B3422W5
Portage,michigan
At that lift, the rocker arm is pointing nearly up & down every rotation (this is a function of lever length vs. lift, nothing to do with ratio). Life expectancy...? Very good point. I mentioned to Jack that when you turn the motor over to check lash it looks like your falling off a cliff at that lift on 59 degree deal. Like he said, lift is more like 740 after deflection. For reference, i ran a 700 roller 7500 pm for years( and often) and never had issue with anything. Ultra bulletproof stuff( Jesel, etc, etc) but valvetrain was never broken.... never spit a pushrod, adj backed off, lash issue. Quiet as a church mouse
[Re: B3422W5]
#2554856
09/26/18 12:54 AM
09/26/18 12:54 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I though the victors moved the shaft away from the valve so you needed a longer rocker on the valve side? Also a longer valve that further compunds the 59* lifter problem and add on top of that the offset? Pretty impressive it dont just cough the PR out under the intake when you crank it over...
[Re: HotRodDave]
#2554857
09/26/18 12:57 AM
09/26/18 12:57 AM
B3422W5
Portage,michigan
I though the victors moved the shaft away from the valve so you needed a longer rocker on the valve side? Also a longer valve that further compunds the 59* lifter problem and add on top of that the offset? Pretty impressive it dont just cough the PR out under the intake when you crank it over... Motor has over 50 pulls on it, spread out over at least 3 sessions, with another upcoming
