Chassis stiffening
#2554172
09/24/18 06:17 PM
09/24/18 06:17 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
If im looking at a b body with around 540 hp and 600 ft lbs MAX (at the flywheel), street tires, and 3.73 gears, what chassis stiffening would be necessary? Im thinking of at least torque boxes and possibly subframe connectors, would anything else be needed? Also, other than rear end (probably putting a dana in) what else would i need to strengthen my car?
Re: Chassis stiffening
[Re: 70charger512]
#2554175
09/24/18 06:27 PM
09/24/18 06:27 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Put in all the boxes and floor plates, weld in subframe connectors, full tube thru the floor are the best IMHO, pull the K frame weld that up, gusset the steering mount, box in the motor mount towers, lower rad support, and side firewall braces are nice additions, improve the welds thru out the unibody, shock towers, rockers, rear rails/floor, transmission crossmember...
[Re: GoodysGotaCuda]
#2554270
09/24/18 10:44 PM
09/24/18 10:44 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Go with through-floor frame stiffeners, I sure wish I did. I'm not impressed with the laser cut rigidity. As a back handed compliment, I would have thought you knew better.
[Re: 70charger512]
#2554340
09/25/18 02:33 AM
09/25/18 02:33 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
From my limited experience with these cars, torque boxes, subframe connectors and a welded & reinforced K-member work wonders. Under fender braces & under radiator support significantly helps stabilize the front end. Add a custom Monte Carlo bar to finish it off and further eliminate cowl shake.
Welding up the rest of the car's unibody welds as mentioned, helps too. It all adds up, and it really helps if you start with a relatively rust free low mileage unbeaten car.
Some upgraded control arms, HD tie rods & sleeves, sway bars bigger torsion bars, stiffer springs and quality shocks will make that stiffer chassis pay off.
Beef up your driveshaft, u-joints and attachments to the rear end and transmission.
If you don't live where it freezes hard run some Nitto drag radials out back to hook it up on the street. If you plan on running common street radials, you can count on traction problems.
If you are running an automatic, spend $ on a quality torque converter matched to your combination. Better yet, put in an overdrive transmission and EFI it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Spaceman Spiff]
#2554345
09/25/18 03:00 AM
09/25/18 03:00 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I clicked on the link. Nothing about chassis stiffening from 15.00 to 24.00. If I were a drag race guy, that would have been time well spent.
[Re: Kern Dog]
#2554699
09/25/18 07:55 PM
09/25/18 07:55 PM
Posts: 91 Calgary, AB
64Bel
Calgary, AB
I clicked on the link. Nothing about chassis stiffening from 15.00 to 24.00. If I were a drag race guy, that would have been time well spent. The chassis stuff was somewhere around the 40 minute mark. 318 TBs, 318 springs, no snubber, no subframe connectors. G70 tires being the limitation.
