Re: How to tell B and RB cranks apart without tools??
[Re: jughed]
#2553520
09/23/18 09:06 AM
09/23/18 09:06 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The main bearing journals are smaller on the B cranks. RBs are 2.750, Bs are 2.675? An RB crank will have a circumference of 8.639 inch, or 8 5/8 plus a touch.
[Re: gregsdart]
#2553622
09/23/18 01:54 PM
09/23/18 01:54 PM
RapidRobert
^^^ cut a strip of paper & measure the circumference then divide Pi into that for the journal diameters Greg posted.
[Re: DoctorDiff]
#2553738
09/23/18 05:52 PM
09/23/18 05:52 PM
RapidRobert
That's too easy! Thanks Doc.
[Re: DoctorDiff]
#2553755
09/23/18 06:21 PM
09/23/18 06:21 PM
gregsdart
You don't have to measure anything.
If the rear main bearing journal is almost the same diameter as the rear main seal journal, you have an RB crank.
If the main bearing journal is noticeably smaller, you have a B crank. Like homer would say,, Doh,,,,!!!!!
[Re: DoctorDiff]
#2553913
09/24/18 12:16 AM
09/24/18 12:16 AM
Posts: 1,229 In The Hills
jughed
In The Hills
The main bearing journals are smaller on the B cranks. RBs are 2.750, Bs are 2.675? An RB crank will have a circumference of 8.639 inch, or 8 5/8 plus a touch. You don't have to measure anything.
If the main bearing journal is noticeably smaller, you have a B crank. Thank you both!! that is what i wanted to know. ...and who keeps a tape measure in their pocket at all times??
[Re: jughed]
#2553975
09/24/18 09:22 AM
09/24/18 09:22 AM
Posts: 4,744 Florida
BDW
[Re: jughed]
#2554002
09/24/18 11:02 AM
09/24/18 11:02 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
..and who keeps a tape measure in their pocket at all times?? Well that would be me, and Ron I guess
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2554029
09/24/18 12:12 PM
09/24/18 12:12 PM
Posts: 43,600 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
You two are almost twins, I know I don't look anything like the hedgehog...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2554067
09/24/18 01:45 PM
09/24/18 01:45 PM
moparmarks
You two are almost twins, I know I don't look anything like the hedgehog... We are twins where it counts.
