Wheel stud and lug nut recommendation #2553332
09/22/18 07:23 PM
09/22/18 07:23 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I am going to run my Cuda and want to swap the stock wheel studs and lug nuts out (I'm using stock type rallye wheels and axles) I'd prefer lug nuts that looks more like the stock ones (of course the open end is ok). Thanks
Re: Wheel stud and lug nut recommendation [Re: UCUDANT] #2553351
09/22/18 08:37 PM
09/22/18 08:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do your wheels have a tapered lug or A shouldered
/shank one
wave
Re: Wheel stud and lug nut recommendation [Re: UCUDANT] #2553390
09/22/18 10:26 PM
09/22/18 10:26 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
They are stock tapered lug nuts.
Re: Wheel stud and lug nut recommendation [Re: UCUDANT] #2553440
09/23/18 12:46 AM
09/23/18 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You dont have much of a choice but you can buy
open end ones that dont have the tin sleeve
on them I hate those tin covers.. Summit has
steel lugs with open ends if you want
wave
Re: Wheel stud and lug nut recommendation [Re: UCUDANT] #2553444
09/23/18 12:59 AM
09/23/18 12:59 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There are also guys on Ebay selling tapered nuts with open ends. Some use a metric-sized hex (17mm) for tight clearances.
Re: Wheel stud and lug nut recommendation [Re: topside] #2553464
09/23/18 02:03 AM
09/23/18 02:03 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If you want nice lug nuts get the Gorilla ones thru Summit etc. They are double the price of many of the others, but are warrantied against flaking, and the threads are cut better so they go on tighter and are more likely to stay tight.
Re: Wheel stud and lug nut recommendation [Re: UCUDANT] #2553846
09/23/18 09:58 PM
09/23/18 09:58 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Second vote for the Gorilla brand.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
