need help identifying my Hemi Motor mounts
#2548206
09/10/18 01:16 AM
09/10/18 01:16 AM
Posts: 102 eastern L.I. ,NYC
kingdragon
eastern L.I. ,NYC
Hi guys. I bought my first Hemi car this weekend and it came with a few extra motor mounts. Can you guys help me identify these? And how do you post pictures?
I only buy MADE IN USA.
Re: need help identifying my Hemi Motor mounts
[Re: ScottSmith_Harms]
#2548261
09/10/18 08:40 AM
09/10/18 08:40 AM
kingdragon
eastern L.I. ,NYC
[quote=ScottSmith_Harms]The dots are the months, numbers are the year. [
/quote]
Yes, I'm aware. Scott, can you tell me the difference between the two steel mounts pictured on left? Which is B-body, which is E?
[Re: kingdragon]
#2548282
09/10/18 10:44 AM
09/10/18 10:44 AM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
I'm not aware of there being a difference in the passenger mount brackets between B/E body. It looks as though the difference in size may be due to whichever vendor made it, including aftermarket vendors. 2 cents.
68 Charger 70 Cuda
[Re: kingdragon]
#2548284
09/10/18 10:46 AM
09/10/18 10:46 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, I'm aware. Scott, can you tell me the difference between the two steel mounts pictured on left? Which is B-body, which is E? Yes I can, but I need the side view pics I asked for (drivers side is B/E specific, Pass side are all the same).
#2548317
09/10/18 11:56 AM
09/10/18 11:56 AM
kingdragon
eastern L.I. ,NYC
Yes, I'm aware. Scott, can you tell me the difference between the two steel mounts pictured on left? Which is B-body, which is E? Yes I can, but I need the side view pics I asked for (drivers side is B/E specific, Pass side are all the same). These passengers are slightly different, as you can see the orange one is slightly bigger. Maybe 3/8" taller when installed in car.
[Re: kingdragon]
#2552986
09/21/18 06:30 PM
09/21/18 06:30 PM
kingdragon
eastern L.I. ,NYC
Bolt holes are exactly the same centerline from edge. Noticeable difference in size, maybe 3/8" +\-
