Re: Hopping up my 318
[Re: Brandon_689]
#2551638
09/18/18 07:40 PM
09/18/18 07:40 PM
Posts: 17 Canada
Brandon_689
Canada
Would it be worth running kb167 and say an edelbrock head with out zero decking it due to I've already sent it machine shop would prefer not to have to take it back. And I know i would just prefer to stick with what is supposed to be in my car
[Re: Brandon_689]
#2551653
09/18/18 08:27 PM
09/18/18 08:27 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
All that said, 360 cores are a dime a dozen. I think you’re onto something there.
[Re: roadrunninMark]
#2551762
09/19/18 12:37 AM
09/19/18 12:37 AM
Porter67
China man must say no selly to greedy American. quote=roadrunninMark]I am doing my 318. I went with the kb167 pistons. I didn't want to deck mine for the same reason as you. I am looking at the Sidewinder heads (63cc) and the soon to be released Trick Flows (60cc). I would like the Sidewinders as the price will be better and I really don't need the TFs. The problem is the vendor can't get them from the supplier, so I may have to go with the TFs. The TFs are gonna be great heads but are more than I want to spend. I think the eBrocks are 65cc? [/quote]
[Re: Porter67]
#2552315
09/20/18 01:58 PM
09/20/18 01:58 PM
RapidRobert
Can we talk you into finding a 360 block & stroking it (4" cranks are cheap nowadays) & the KB 356 (iirc) pistons ain't too bad. NOBODY that I have even spoken with that has stroked one has regretted the reasonable time/expense it takes to do one. You get alot of cubes (408) in a SB package. You have a bit invested in the 318 but I dont think you will get what you are seeking from it & once the 408 fries the tires one time you will forget all about that 318!
