Tire Shake #2551403
09/18/18 10:03 AM
09/18/18 10:03 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Tire Shake [Re: bigdad] #2551457
09/18/18 12:16 PM
09/18/18 12:16 PM
moparx Offline
moparx  Offline
eek
beer
Re: Tire Shake [Re: bigdad] #2551507
09/18/18 02:21 PM
09/18/18 02:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I took gopro vid of my rear suspension and tires to get a handle on my top end tire shake..
Monty Smith really helped me get a handle on it. It boils down to tire selection and power management.
Re: Tire Shake [Re: bigdad] #2551522
09/18/18 02:52 PM
09/18/18 02:52 PM
IL
furious70 Offline
furious70  Offline
IL
What are some general guidelines - I could imagine a matrix of firmness of tire and power application strategy?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Tire Shake [Re: bigdad] #2551552
09/18/18 03:44 PM
09/18/18 03:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pretty typical for a dragster to shake in the burnout, Hoosier equipped cars tend to be a bit worse about it as well. It is all about wheelspeed in the burnout being the culprit.
After the release of the button wheelspeed and shock setting play a big roll especially in higher power stuff and dragsters. To soft a shock or to much air pressure can cause a moderately powered dragster to shake the car apart. It also happens in door cars but they are not as susceptible to it as pipe racks are, but the causes are the same.
Here is a video of our dragster on a not so horrible shake session. Stiffen the shocks up a click and knock some air out of it and was all good. Just misread the track a bit. We have had it shake so bad it broke beadlock bolts and bars..This is a moderately powered(1000hp) 4 link car
https://www.youtube.com/watch?v=3Hslwkm9zps
Take out a 1/4lb of air and one stiffer on the shock and viola all new car
https://www.youtube.com/watch?v=tF4QXmXRqU4
Re: Tire Shake [Re: Al_Alguire] #2551587
09/18/18 05:18 PM
09/18/18 05:18 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
