Re: Indy aluminum blocks
[Re: dvw]
#2551406
09/18/18 10:06 AM
09/18/18 10:06 AM
Posts: 315 Northeast Indiana
73DAD
Northeast Indiana
My Mega blocked trimmed up is 274lbs w/caps. Doug That's impressive! What was your 'before' weight? 320ish?
[Re: racerx]
#2551446
09/18/18 11:59 AM
09/18/18 11:59 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I have a 30 over 1970 iron block and it weighs 260lbs has some trimming, not much. I think the other factory iron blocks I have weigh a few lbs more depending on the bore size. A friend of mine has been running a Aluminum Indy block and has had a lot of trouble over the years keeping the motor together. 605 CI, lots of HP Callies Crank, Stage V Heads on and on. He is now going to use the new KB Block for his next build that is being done at present because he thinks the Indy block might be moving around and causing his problems.
1971 HEMI E BODY REGISTRY
[Re: dvw]
#2551483
09/18/18 01:18 PM
09/18/18 01:18 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
My Mega blocked trimmed up is 274lbs w/caps. Doug Thats pretty trimmed up! my world mega HEMI block 4.5 bore was around 325lbs
[Re: racerx]
#2551553
09/18/18 03:50 PM
09/18/18 03:50 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
I have had a few KB and couple of Indy blocks. NONE have been under 127lbs and that was a low deck deal with a big cam core.
[Re: Al_Alguire]
#2694200
09/04/19 06:06 AM
09/04/19 06:06 AM
Posts: 4,074 Mo.
racerx
Mo.
Any new combos out there on either blocks? preferably power adders.
[Re: racerx]
#2694387
09/04/19 03:05 PM
09/04/19 03:05 PM
Posts: 36 PA
Ody1003
PA
Waiting on block for 10 weeks and just informed castings are not in,(note:block paid in full including freight) be 4 weeks more. From when? built and sold many blocks from them in 20 yrs. Note: 1. pressure test,pressure test upon arrival,If your guy can't do it find someone who can. 2. do not let them do any final machining 3. their cnc stroke clearance is spot on, have them do it, de-burr the heck out of it. 4. Cams don,t turn in block, got to fix it. 5. lifter bore size is mayhem, fix it 6. Deck square and parallel un-finished is not good. Do not let them finish deck,and good luck with your given CH on 10.720 deck with what your finished corrected deck will be. 7. Cut main caps loose, re-torque then re-align hone as needed. Ya I know its new, do it 8. If you want pushrod/lifter oiling have them prep it. Hard to find someone that is capable of gun drilling later. 9. There is more, I'm done, Yes they will handle lots of power we can make with our given selection of components, but not experienced with boosted applications
[Re: Ody1003]
#2694454
09/04/19 07:08 PM
09/04/19 07:08 PM
Posts: 4,074 Mo.
racerx
Mo.
Waiting on block for 10 weeks and just informed castings are not in,(note:block paid in full including freight) be 4 weeks more. From when? built and sold many blocks from them in 20 yrs. Note: 1. pressure test,pressure test upon arrival,If your guy can't do it find someone who can. 2. do not let them do any final machining 3. their cnc stroke clearance is spot on, have them do it, de-burr the heck out of it. 4. Cams don,t turn in block, got to fix it. 5. lifter bore size is mayhem, fix it 6. Deck square and parallel un-finished is not good. Do not let them finish deck,and good luck with your given CH on 10.720 deck with what your finished corrected deck will be. 7. Cut main caps loose, re-torque then re-align hone as needed. Ya I know its new, do it 8. If you want pushrod/lifter oiling have them prep it. Hard to find someone that is capable of gun drilling later. 9. There is more, I'm done, Yes they will handle lots of power we can make with our given selection of components, but not experienced with boosted applications Thaxs for the advice......
[Re: dvw]
#2694498
09/04/19 10:02 PM
09/04/19 10:02 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I've built a few hemis using indy blocks for other people. The trouble i see with all of the indy aluminum water blocks is that the cylinders move around dramatically above 1000 hp. Every one of them ive done, has done it, killing power. Like thats the power limiter..make 1200 and watch the numbers fall as you run it. I don't think they're going to fly apart, but the cylinders do not stay round. KB is a different story entirely, at least the old ones. Haven't been able to do a new one yet.
Indy is made from white glue and wood chips.
[Re: dthemi]
#2694501
09/04/19 10:10 PM
09/04/19 10:10 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
Our bores on our Indy were .007 out of round and .011 taper....There was not enough left to correct it all....And yes when the Indy heats up, the bores shift a little. I am not sure if their sleeves are too thin, or there is not enough aluminum behind them. I would rather have a billet water block at this point...
[Re: dthemi]
#2694570
09/05/19 05:02 AM
09/05/19 05:02 AM
Posts: 4,074 Mo.
racerx
Mo.
Indy is made from white glue and wood chips. This scares me .....I no of one fellow racer that runs a dart (Ford) block that is boosted has concert in it to make it more solid.
[Re: racerx]
#2694600
09/05/19 08:30 AM
09/05/19 08:30 AM
dthemi
back in Georgia
In fairness, 1000hp used to be a big number. These days telling someone you made 1000 gets the what's wrong with it question.
Nitrous, blowers, turbos, have for sure become the norm. Every project i see now has a power adder and not just a small plate. More often than not it's 3 foggers, or forced induction, myself included.
The old KB stuff would move around too on the first build, but would take a set, and stay there. I can't say what the limit is on the old stuff but i know they stay pretty round at 2000hp. The old KB design (wet sleeve ones) were in TF at one point in history. Not really the same as the dry sleeve blocks, but close.
I'm hopeful for the new KB stuff. Any improvement in the orig design will be a home run.
I'm going billet, or solid from here on out personally.
Back on topic though, if you can wait for a kb, do so. Ultimately the indy will bite you if you're a power adder guy.
[Re: dthemi]
#2694627
09/05/19 10:10 AM
09/05/19 10:10 AM
Posts: 4,694 On the parachute mount
n20mstr
Back on topic though, if you can wait for a kb, do so. Ultimately the indy will bite you if you're a power adder guy. My Indy block has been difficult to seal up the bore... I have been trying for almost 15 years now. Ever since I have ran a vacuum pump I see the vac has been hard to get, and hard to keep. My local machine shops hone could only net me 5-7 vac going down the track. (this is with nitrous) Now the most recent hone was done at BES. Not sure what they do (hot honing etc) but they told me the bores were not round. Now it has 9-10 going down the track ( I still have a stock timing cover so the stock type front seal it limiting me to 10) Also what I have been doing at BES recommendation is to run it at 90 - 110* on the starting line. It does seem to help, and a Dale Cubic carb lets it go on the brake at literally ANY temp...
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2694665
09/05/19 11:48 AM
09/05/19 11:48 AM
dthemi
back in Georgia
There's a huge difference in hone jobs for sure. Most of the straight, correct RA jobs are diamond head. The movement in the bores just is what it is. My nitrous KBs start moving noticeably around 1500hp. Thats with warren Johnson, or Kurt hone job. Some have been higher, and every block is a little different. I have a roots blown one that made over 1600on the dyno at 10 over. I've been at 30 over, detonated it, smoked and some pistons. Pulled the head, cleaned the aluminum off the bores, and the thing is still less than a thou out of round. Dingle honed it, slapped in new slugs, put the tune back and go cat go.
I'm getting a billet next, but I'll be filling all my kbs to the water port to see if it helps in the future. All my junk is race only so who cares.
[Re: n20mstr]
#2694669
09/05/19 11:50 AM
09/05/19 11:50 AM
Al_Alguire
Las Vegas
The bore issue is the very same thing I have seen with the Indy stuff which is why I prefer KB, but since they seem to unobtanium what ya gonna do. Speaking of that if you are waiting on an Indy block Indy has lost their foundry as well, so plan on the wait to continue.
[Re: hudsonhornet7x]
#2694714
09/05/19 03:26 PM
09/05/19 03:26 PM
Al_Alguire
Las Vegas
That's NOT BMP running that auction on ebay. I do have a buddy who owns a machine shop here in town that just got one after an 8 month wait. Better than KB....Oh yeah they lost their foundry as well but have found a new one apparently.
