Re: What will it run
[Re: DusterKid]
#2550681
09/16/18 05:14 PM
09/16/18 05:14 PM
Posts: 570 UK
rb446
UK
Yep^^.... those heads can hold up to around 500hp (250cfm), but are somewhat of a choke point on a 408, so assuming you have around 460 on track hp, and your chassis is ok, your ticket could look like this>
60 Foot E.T. : 1.55 1/8 Mile E.T. : 7.05 1/8 Mile Trap Speed : 96.38 1/4 Mile E.T. : 11.18 1/4 Mile Trap Speed : 120 1/4 Mile Trap RPM : 6,128+slip
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: DusterKid]
#2550704
09/16/18 06:38 PM
09/16/18 06:38 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
When I had the 340 in my Dart it ran 11.60 @ 116 and 7.24 @ 94ish on pump 93 at 3460#. It was .030 over, 11.4-1, Curtis Boggs ported Edelbrocks, 236/242 @ .050, .586/592 hydraulic, X-Cellerator intake, QF Q-750, 9.5" converter that flashed 5000, 8 3/4 with 4.30 gears on 275 MT radials.
I'm thinking 11.50's for the OP.
[Re: DusterKid]
#2550947
09/17/18 10:31 AM
09/17/18 10:31 AM
Posts: 570 UK
rb446
UK
Yeah with a 1.51 60 it should look like this with good air> 60 Foot E.T. : 1.51 1/8 Mile E.T. : 6.87 1/8 Mile Trap Speed : 98.90 1/4 Mile E.T. : 10.89 1/4 Mile Trap Speed : 123 and thats 497fwhp, I'm sure with better TF heads it'll show.
[Re: rb446]
#2551016
09/17/18 12:42 PM
09/17/18 12:42 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Yeah with a 1.51 60 it should look like this with good air> 60 Foot E.T. : 1.51 1/8 Mile E.T. : 6.87 1/8 Mile Trap Speed : 98.90 1/4 Mile E.T. : 10.89 1/4 Mile Trap Speed : 123 and thats 497fwhp, I'm sure with better TF heads it'll show. He has sounds like a good convertor, and the car has 4.56 gears. My guess is the front half looks better than the back half would have, especially with small headers and a stock head wifh a 4 inch arm.Very good 60 foot Still, probably 11 flat or close. Very nice job for first outing!!!!! Before i invested in the trick flows, i would send the eddies out to Modern and have them CNC ported. They have an excellent program. Easily another 50-70 horse laying on the table to take advantage of just by the head porting alone.
[Re: B3422W5]
#2551024
09/17/18 12:49 PM
09/17/18 12:49 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yeah with a 1.51 60 it should look like this with good air> 60 Foot E.T. : 1.51 1/8 Mile E.T. : 6.87 1/8 Mile Trap Speed : 98.90 1/4 Mile E.T. : 10.89 1/4 Mile Trap Speed : 123 and thats 497fwhp, I'm sure with better TF heads it'll show. He has sounds like a good convertor, and the car has 4.56 gears. My guess is the front half looks better than the back half would have, especially with small headers and a stock head wifh a 4 inch arm.Very good 60 foot Still, probably 11 flat or close. Very nice job for first outing!!!!! Before i invested in the trick flows, i would send the eddies out to Modern and have them CNC ported. They have an excellent program. Easily another 50-70 horse laying on the table to take advantage of just by the head porting alone. Let me fix this for you. Easily and I said easily 100-120 horsepower left in those heads and the intake needs work too
[Re: DusterKid]
#2551028
09/17/18 01:06 PM
09/17/18 01:06 PM
Posts: 570 UK
rb446
UK
That is very true, either Modern or Pittsburgh can do an excellent 300cfm+ job on them if needed, no need to spend $2000 on TF's, then we would see some numbers, like mid 10's or better!!....and yes that is a good 60@1.51.
[Re: rb446]
#2551034
09/17/18 01:30 PM
09/17/18 01:30 PM
B3422W5
Portage,michigan
That is very true, either Modern or Pittsburgh can do an excellent 300cfm+ job on them if needed, no need to spend $2000 on TF's, then we would see some numbers, like mid 10's or better!!....and yes that is a good 60@1.51. Thats true, potential is there to pick up that much power. The reason i said more like 50-70 is because with his current combo, thats more likely reality. The cam is relatively small with probably 540ish true net lift, and the headers are small too. With a 1 7/8 header and bigger cam to take more advantage of the bigger head, your right. And no need to sound cocky about it......” let me fix this for you” type stuff. What i said didnt need fixing
[Re: B3422W5]
#2551059
09/17/18 02:08 PM
09/17/18 02:08 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That is very true, either Modern or Pittsburgh can do an excellent 300cfm+ job on them if needed, no need to spend $2000 on TF's, then we would see some numbers, like mid 10's or better!!....and yes that is a good 60@1.51. Thats true, potential is there to pick up that much power. The reason i said more like 50-70 is because with his current combo, thats more likely reality. The cam is relatively small with probably 540ish true net lift, and the headers are small too. With a 1 7/8 header and bigger cam to take more advantage of the bigger head, your right. And no need to sound cocky about it......” let me fix this for you” type stuff. What i said didnt need fixing Man you have a bug up your azz lately. And it’s not all about cam lift as I’ve gone 9.80’s with a 520 lift. Carry on.
[Re: DusterKid]
#2551071
09/17/18 02:28 PM
09/17/18 02:28 PM
B3422W5
Portage,michigan
I never said it was all about cam lift. With his current combo just putting ported heads on isn’t going to add 100-120 horsepower. You attacked my statement as being untrue. It wasnt. Sure, big roller, ported intake, bigger headers, more compression, etc, it’s going to pick up more. No bug up my butt at all. Like you I have had a number of Eddie headed combos myself the last 20 years or so, including one currently. What he has runs good. Simply putting ported heads on what he has would probably pick the car up 3 tenths, maybe a hair more
[Re: DusterKid]
#2551167
09/17/18 05:59 PM
09/17/18 05:59 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Considering the current cam and small headers, plus unported heads, I have to ask, what would an Airgap , one inch spacer and 850 do for this combo? Or is the Victor intake close enough in runner size to not hurt power?
[Re: DusterKid]
#2551230
09/17/18 07:51 PM
09/17/18 07:51 PM
Posts: 570 UK
rb446
UK
As its an easy swap for now, I would for sure try an 850/950DP if he could borrow one or has one, also try a 1" spacer as well, I think it could pick up 2/10ths, just like my little 340 did with stock heads from a 750>850DP....be interesting to see, could be even more?....think Mopar V8, think big carbs especially with 4.56/5000 stall and a victor intake, 750 is puny in my book with that set up....the larger hdrs/heads can come later...squeeze what you can first with what you have and easy bolt-ons/tuning, the chassis is already good....could shift it a tad more than 6k though I think with 256/268 @ 50 dur and see if it picks up mph which it should with the bigger carb.
[Re: DusterKid]
#2551247
09/17/18 08:42 PM
09/17/18 08:42 PM
fast68plymouth
So. Burlington, Vt.
could shift it a tad more than 6k though IMO, with unported heads and the small headers, it won’t respond favorably to high shift points, but a lot of that depends on the motor and converter interaction. I also feel like it would front half better than back half in its current configuration. Easy enough to find the answer to both of those questions though...... try different shift points at a 1/4 mile track.
