Brain Fart #2550350
09/15/18 04:52 PM
09/15/18 04:52 PM
MR_P_BODY Offline OP
What are the 2 point to prime a SB on the
crank.. I forgot today... Thanks
wave
Re: Brain Fart [Re: MR_P_BODY] #2550382
09/15/18 06:37 PM
09/15/18 06:37 PM
Anyone know.. thanks
wave
Re: Brain Fart [Re: MR_P_BODY] #2550400
09/15/18 07:16 PM
09/15/18 07:16 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I remember seen it mentioned somewhere.
Trying to find it again.
Here it is:
https://www.forabodiesonly.com/mopar/threads/la-360-rocker-arm-oiling.329921/#post-1971008100
Originally Posted By "70aarcuda"
On a small block:
Turn the motor to 90* before top dead center coming up on #1 compression. The pass. side rockers should get oil.
Turn the motor to 20* after top dead center just past #6 compression. The drivers side rockers should get oil.
Re: Brain Fart [Re: BigBlockMopar] #2550403
09/15/18 07:21 PM
09/15/18 07:21 PM
If I recall correctly one of them 120* on the
wheel
EDIT
thanks for the info.. sucks getting OLD
wave
Re: Brain Fart [Re: MR_P_BODY] #2550434
09/15/18 09:37 PM
09/15/18 09:37 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Mr P. I think this is one of those things you will forget more than I'll ever know.. that being said I never knew the exact location but what I have done in the past is pull the plugs turn the oil pump with a cordless and get someone to bump the starter
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Brain Fart [Re: MR_P_BODY] #2550485
09/16/18 12:15 AM
09/16/18 12:15 AM
Cab_Burge Online work
Cab_Burge  Online Work
wheel
EDIT
wave
Me thinks I don't like the alternative so much either right now whistling
I'm ready when called though up grin
