Page 1 of 7 1 2 3 4 5 6 7
Just returned from the track....Something is wrong!!! #254881
03/15/09 07:41 PM
03/15/09 07:41 PM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
Took the 68 Barracuda to the track today. Something isnt right. The basics of the combo are a 360, Edelbrock RPM 65cc heads (OOTB), 11.2:1, 292/509 cam, Weiand X-celerator, 750DP, Hooker 1 5/8" headers, 2 1/2" exhaust, Holley Blue pump (still running 5/16" line), 4-speed, 4.10 SG on 275/60-15DR's. The car was hooking fine launching at 4800 rpm. Ill list the details of the timeslip below...
60'---1.841
330'---5.374
1/8---8.408
1/8 MPH---82.98
1000'---10.912
1000' MPH---95.00
1/4 ET---13.125
1/4 MPH---106.03
That was the best run of the day. I made a total of 6 passes and each one got slower and slower.
The only thing I changed was I went from a Action Plus to the X-celerator manifold, and installed a new timing set. It sounds like a stupid question, but could I have installed the timing set a tooth off or something or could it be running out of fuel on the top end because of the 5/16" line? It has 3-5in of vacuum at 900-1000rpm. It just seems lazy. It wont even break the tires loose in first gear on the street. Anyone have any ideas? I figured this thing would run way better than what it did.
Re: Just returned from the track....Something is wrong!!! [Re: 69L78Nova] #254882
03/15/09 07:46 PM
03/15/09 07:46 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
are you running lean? whats your initial timing at? that cam likes timing. whats your cranking compression? check the basics first.
Re: Just returned from the track....Something is wrong!!! [Re: Baxter61] #254883
03/15/09 07:48 PM
03/15/09 07:48 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Im running 36* all in by 2600rpm. Im gonna do a compression test in a little bit and see what I can find out. The plugs looked good after every pass
Re: Just returned from the track....Something is wrong!!! [Re: 69L78Nova] #254884
03/15/09 07:59 PM
03/15/09 07:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Are you running KB pistons? If so back off your timing and try it. They don't seem to like a whole bunch of advance. Did you degree the cam in?? Give it about 4 degrees advance and bring the power band down somewhat.
Re: Just returned from the track....Something is wrong!!! [Re: MoparforLife] #254885
03/15/09 08:11 PM
03/15/09 08:11 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Sounds like a timing issue to me also. With my 360 I timed it at 32* all in at 3000rpm. You may have to double check the timing chain and gears, the dots could be stamped wrong.
Re: Just returned from the track....Something is wrong!!! [Re: Posest] #254886
03/15/09 09:00 PM
03/15/09 09:00 PM
Az
Crizila Offline
Crizila  Offline
Az
You can cut the timing back 3-4 degrees, but it's not gonna help you out much. You need atleast a 3/8" fuel line - and thats out of the tank. To run in the low to mid 12"s, which is where you should be running, your fuel pump should be able to fill a one gallon can in about 30 seconds - minimum - and thats measured from where the fuel line connects to the carb. Forget what the pump MFG. tells you. You need to actually check it to be sure. Your 60 foot times are off about a tenth and 1/2 also, indicating you have a traction problem.
Fastest 300
Re: Just returned from the track....Something is wrong!!! [Re: Crizila] #254887
03/15/09 09:05 PM
03/15/09 09:05 PM
Az
Crizila Offline
Crizila  Offline
Az
You also have engine issues with only 3-5 " of vacuum at idle. You should have atleast 12" @ idle with your combo. Sounds like you have a pretty hefty vacuum leak somewhere.
Fastest 300
Re: Just returned from the track....Something is wrong!!! [Re: Crizila] #254888
03/15/09 09:10 PM
03/15/09 09:10 PM
Kirkland, Washington
Pacnorthcuda Offline
He has a traction problem alright! He states above that he can't even break em loose in first on the street! The fuel line is the last of his worries. Degree/advance the cam, make sure no vacuum leak.
Re: Just returned from the track....Something is wrong!!! [Re: Posest] #254889
03/15/09 09:37 PM
03/15/09 09:37 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Just checked vacuum at idle again. Was around 3-4in at 900rpm. Cranking compression was 140 across all 8
Re: Just returned from the track....Something is wrong!!! [Re: 69L78Nova] #254890
03/15/09 09:38 PM
03/15/09 09:38 PM
Do you know what your vacuum was BEFORE the timing chain swap???
Re: Just returned from the track....Something is wrong!!! [Re: Pacnorthcuda] #254891
03/15/09 09:40 PM
03/15/09 09:40 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
It was always around 3-4 inches of vacuum at 1000rpm. Even before the timing set and intake manifold swap. Im baffled
Re: Just returned from the track....Something is wrong!!! [Re: Pacnorthcuda] #254892
03/15/09 09:41 PM
03/15/09 09:41 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I agree, check for vauum leaks, and degree cam.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Just returned from the track....Something is wrong!!! [Re: 69L78Nova] #254893
03/15/09 09:44 PM
03/15/09 09:44 PM
So Cal
So Cal
Some gear sets have been known to be drilled incorrectly.
You never mention what you ran before.
Is it possible you bent a valve, changing the timing set? Did you turn the crank when the cam gear was off?
Re: Just returned from the track....Something is wrong!!! [Re: HealthServices] #254894
03/15/09 10:12 PM
03/15/09 10:12 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
somethings wrong. my old 340 with 10.2:1 compression and the 282 cam had 8" or so vacuum and the cranking compression was 175-180 lbs or so
Re: Just returned from the track....Something is wrong!!! [Re: aarcuda] #254895
03/15/09 11:02 PM
03/15/09 11:02 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, I just pulled it apart, and the timing marks are a half a tooth off. Either way I turn them, I cant get the dots to line up correctly. This thing never had any more than 3-4 inches of vacuum at idle, even before the timing set and intake swap. Could there be a problem with the cam itself, considering MP's reputation of poor quality products within the past few years? This was a used cam that I got from a friend of mine that "said" he kept all of the lifters in line with their respective lobes
Re: Just returned from the track....Something is wrong!!! [Re: 69L78Nova] #254896
03/15/09 11:17 PM
03/15/09 11:17 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
you need to degree your cam in. I put mine in at 108 in my 340 that was right around 10.5:1 and had about 150 cranking compression. It liked the timing to be locked out at 36* and I could get about 9 to 11 inches of vacuum out of it, thats the only way it ever ran right. In small blocks, that cam likes the timing to be locked out. and if you never degree your cam, you'll never know where its at. dont go by "half a tooth off" buy a cam key set, and put it where you want it. anywhere from 108 to 104 is ok with that cam.
Re: Just returned from the track....Something is wrong! [Re: Baxter61] #254897
03/15/09 11:21 PM
03/15/09 11:21 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
also double ck the cam itself maybe its flat... my stock long block 340 with manifolds ran 12,s..stock converter and street tires.. put an LD 340 on it with a 750 DP and a small solid in it... low 12,s all day.. dan
Re: Just returned from the track....Something is wrong! [Re: ph23vo] #254898
03/15/09 11:31 PM
03/15/09 11:31 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'm running a 260/266 @ .050" cam and I've got 6 1/2" of vac.
As mentioned, I'd degree the cam first [ EDIT: set the timing] then check for vac leaks.
Re: Just returned from the track....Something is wrong! [Re: 64Post] #254899
03/15/09 11:33 PM
03/15/09 11:33 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
I dont get where the vacuum leak would be coming from though. I have had two different intake manifolds on here. I forgot to add I am still running the stock stamped steel rocker arms. I figured Id throw that in as well
Re: Just returned from the track....Something is wrong! [Re: 69L78Nova] #254900
03/16/09 12:24 AM
03/16/09 12:24 AM
So Cal
So Cal
After you get the cam gear straighten out, do a leak down. Just to make sure you did not kiss a valve in the past.
