1992 D 350 diesel leak hellp #2548713
09/11/18 11:44 AM
09/11/18 11:44 AM
Oly Wash
racerlall Offline OP
Oly Wash
so my 1992 1 ton leaking diesel fuel from the injector pump head the big plug in the middle of the injector lines like in these photos from Mike 93
so can I remove just the plug and replace the O ring on the truck or am I oping up a can of worms and springs N things that will go fling every ware
thanks for looking
Re: 1992 D 350 diesel leak hellp [Re: racerlall] #2550928
09/17/18 08:40 AM
09/17/18 08:40 AM
Guitar Jones Offline
Here is a parts diagram.
VE pump
