Motor oil for 440-6 car? #2548566
09/10/18 11:07 PM
09/10/18 11:07 PM
California
Luis Zavala Offline OP
California
Wondering what kind of motor oil is best to use on a 440-6 car. Let me know please. I appreciate the help.
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548575
09/10/18 11:31 PM
09/10/18 11:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
10w40
Re: Motor oil for 440-6 car? [Re: stumpy] #2548577
09/10/18 11:36 PM
09/10/18 11:36 PM
California
California
What type? I was told it should be one with zinc because it is an anti wear addictive. Is that the correct type to use? Is it recommended? Anyone have any specific brands or specific motor oil?
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548582
09/10/18 11:58 PM
09/10/18 11:58 PM
tucson az
frank Offline
frank  Offline
tucson az
I use Brad Penn 20W-50 in my RB 496
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548583
09/10/18 11:58 PM
09/10/18 11:58 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I feel over the last few years, most will suggest either Brad Penn, Driven, Schaeffer and a few will chime in with Valvoline VR1. There will also be some still stuck on Rotella however; a lot of the good stuff has been taken out of it over the past 5-10 years but, again, some are still stuck on it. You'll also have some chime in with X oil with a zinc additive etc.
I personally have used Brad Penn for years without issue but, over the past few years especially since the company changed hands, many including some well known engine builders will say that it has changed and they have stopped using it due to some wear issues seen during rebuilds. I still have some old stock along with some I've purchased more recently, I normally mix half of the old with the new. I've still not had any issue but, I may be going to Driven in the future. I don't build these things every day but, will defer to those who do and trust what some have reported.
Now, sit back, gab some popcorn and hold on because this normally is a touchy subject.
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548588
09/11/18 12:03 AM
09/11/18 12:03 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I use Delo 400 with a bottle of Comp Cams Additive. The Delo 400 with the black cap is the old formula which is better than the new formula with a red cap.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548590
09/11/18 12:05 AM
09/11/18 12:05 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually run Royal Purple HPS 10w30 or 10w40 with either a Royal Purple or Wix filter
Re: Motor oil for 440-6 car? [Re: parksr5] #2548592
09/11/18 12:06 AM
09/11/18 12:06 AM
70sixpkrt Offline
70sixpkrt  Offline
iagree
4-speed
3:54 Dana
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548596
09/11/18 12:10 AM
09/11/18 12:10 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Valvoline VR1 10-30
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548598
09/11/18 12:25 AM
09/11/18 12:25 AM
Where in CA do you live and drive your six pack car? If west of the Sierra Mtns. near the coast I would and did , use 5 20 WT in the winter and 10W30WT in the summers, straight petroleum base, not synthetic if the motor has over 5000 miles since built or rebuilt tsk
Make sure and use a good quality Zinc additive with every oil change.
if your east on the Mtns. out in the desert then use 10w30WT in the winter and 10w40WT in the summer or maybe even 2w50WT in the summer with the Zinc additive if your in the low desert like Barstow or lower up
Re: Motor oil for 440-6 car? [Re: Cab_Burge] #2548612
09/11/18 12:52 AM
09/11/18 12:52 AM
California
California
I’m in Southern California in a valley. So it’s pretty hot here. And yes I drive my bird about twice a week
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548620
09/11/18 01:27 AM
09/11/18 01:27 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I use Kendall 10w40 with a little GM EOS added in and a NAPA Gold filter. Also have a filter mag as well.
I used to run Valvoline, but the Kendall oil is very similar and much cheaper to buy in bulk at a local commercial oil retailer. Parts store oil prices here practically doubled back around 07-08 and never really went back down.
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548686
09/11/18 10:35 AM
09/11/18 10:35 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
VR1 20/50 Here
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548706
09/11/18 11:30 AM
09/11/18 11:30 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Viscosity choice will be based on clearances and oil pressure for YOUR engine.
In our 440-6 with slightly less than .003 (rods and mains),
we use 10-30 VR1 and have 70# at cold start-up, 20# at hot idle, we're happy.
Joe
Re: Motor oil for 440-6 car? [Re: BloFish] #2548714
09/11/18 11:44 AM
09/11/18 11:44 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Originally Posted By BloFish
Valvoline VR1 10-30
iagree
I have ran 10-30 in the winter and 20-50 in the summer in my 540" Hemi with a flat tappet cam for years. And I ran it in my 500" wedge for years before that. You can spend more money and jump through more hoops to buy some "specialty" oil, but your engine will be just as happy with the readily available VR-1.
Master, again and still
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548752
09/11/18 01:16 PM
09/11/18 01:16 PM
AndyF Offline
AndyF  Offline
It doesn't really matter. Just grab anything that is on sale that is roughly the correct viscosity. Trust me, it really doesn't matter that much. I use the cheapest stuff that Costco sells in race engines all the time.
Re: Motor oil for 440-6 car? [Re: AndyF] #2548792
09/11/18 02:19 PM
09/11/18 02:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
iagree
This isn't what anyone wants to hear, especially oil dealers, but it's been my experience as well. Improper break in, lack of lifter rotation on flat tappet applications, questionable parts quality, excessive spring pressure, excessive rpm and so on probably aren't considered as often as they should be.
I do tend to stash some away when I can get a deal. A few years ago I finally used up the last of my Valvoline Racing 30 stash (old enough to be pre-VR1) and switched to more modern stuff for flat tappet break in. Delo 400 SAE 30 works just as well. People talk about old oil formulas like they were the holy grail, I've seen analysis of them and they really weren't too impressive.
For nearly stock flat tappet stuff, I don't feel anything special is really needed.
Rich H.
Esse Quam Videri
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548795
09/11/18 02:26 PM
09/11/18 02:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
This isn;t 1970 where there was a large variance in oil quality and such.
All oils that show an API spec have to meet fair tight tolerances leading them to meet the same minimum level of quality and requirements. Anything above that level is gravy that's probably turd polishing for all intents and purposes.
Oils without an API cert, well you can believe their crap shoot info if you want. I always wonder why they won't certify.
Don't be the exception.
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548803
09/11/18 02:45 PM
09/11/18 02:45 PM
AndyF Offline
AndyF  Offline
I haven't seen a non cert oil for sale anywhere that I buy oil. WalMart, Costco, Napa, etc. Might be able to find a non cert oil in a farm and tractor supply place or something like that?
Re: Motor oil for 440-6 car? [Re: Luis Zavala] #2548809
09/11/18 03:02 PM
09/11/18 03:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Lots of Amsoil stuff doesn't have API cert
Cue fanboyz
