Re: Motor oil for 440-6 car?
[Re: Luis Zavala]
#2548583
09/10/18 11:58 PM
09/10/18 11:58 PM
Posts: 889 Oh
parksr5
Oh
I feel over the last few years, most will suggest either Brad Penn, Driven, Schaeffer and a few will chime in with Valvoline VR1. There will also be some still stuck on Rotella however; a lot of the good stuff has been taken out of it over the past 5-10 years but, again, some are still stuck on it. You'll also have some chime in with X oil with a zinc additive etc.
I personally have used Brad Penn for years without issue but, over the past few years especially since the company changed hands, many including some well known engine builders will say that it has changed and they have stopped using it due to some wear issues seen during rebuilds. I still have some old stock along with some I've purchased more recently, I normally mix half of the old with the new. I've still not had any issue but, I may be going to Driven in the future. I don't build these things every day but, will defer to those who do and trust what some have reported.
Now, sit back, gab some popcorn and hold on because this normally is a touchy subject.
[Re: Luis Zavala]
#2548590
09/11/18 12:05 AM
09/11/18 12:05 AM
Posts: 18,157 Mass
DAYCLONA
Mass
What type? I was told it should be one with zinc because it is an anti wear addictive. Is that the correct type to use? Is it recommended? Anyone have any specific brands or specific motor oil? I usually run Royal Purple HPS 10w30 or 10w40 with either a Royal Purple or Wix filter
[Re: Luis Zavala]
#2548598
09/11/18 12:25 AM
09/11/18 12:25 AM
Posts: 43,215 Bend,OR USA
Cab_Burge
Where in CA do you live and drive your six pack car? If west of the Sierra Mtns. near the coast I would and did , use 5 20 WT in the winter and 10W30WT in the summers, straight petroleum base, not synthetic if the motor has over 5000 miles since built or rebuilt Make sure and use a good quality Zinc additive with every oil change. if your east on the Mtns. out in the desert then use 10w30WT in the winter and 10w40WT in the summer or maybe even 2w50WT in the summer with the Zinc additive if your in the low desert like Barstow or lower
[Re: Luis Zavala]
#2548706
09/11/18 11:30 AM
09/11/18 11:30 AM
Posts: 1,318 Ohio
jlatessa
Ohio
Viscosity choice will be based on clearances and oil pressure for YOUR engine.
In our 440-6 with slightly less than .003 (rods and mains), we use 10-30 VR1 and have 70# at cold start-up, 20# at hot idle, we're happy.
Joe
[Re: Luis Zavala]
#2548752
09/11/18 01:16 PM
09/11/18 01:16 PM
Posts: 31,046 Oregon
AndyF
Wondering what kind of motor oil is best to use on a 440-6 car. Let me know please. I appreciate the help. It doesn't really matter. Just grab anything that is on sale that is roughly the correct viscosity. Trust me, it really doesn't matter that much. I use the cheapest stuff that Costco sells in race engines all the time.
[Re: AndyF]
#2548792
09/11/18 02:19 PM
09/11/18 02:19 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Wondering what kind of motor oil is best to use on a 440-6 car. Let me know please. I appreciate the help. It doesn't really matter. Just grab anything that is on sale that is roughly the correct viscosity. Trust me, it really doesn't matter that much. I use the cheapest stuff that Costco sells in race engines all the time. This isn't what anyone wants to hear, especially oil dealers, but it's been my experience as well. Improper break in, lack of lifter rotation on flat tappet applications, questionable parts quality, excessive spring pressure, excessive rpm and so on probably aren't considered as often as they should be. I do tend to stash some away when I can get a deal. A few years ago I finally used up the last of my Valvoline Racing 30 stash (old enough to be pre-VR1) and switched to more modern stuff for flat tappet break in. Delo 400 SAE 30 works just as well. People talk about old oil formulas like they were the holy grail, I've seen analysis of them and they really weren't too impressive. For nearly stock flat tappet stuff, I don't feel anything special is really needed.
Rich H.
Esse Quam Videri
[Re: Luis Zavala]
#2548795
09/11/18 02:26 PM
09/11/18 02:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
This isn;t 1970 where there was a large variance in oil quality and such.
All oils that show an API spec have to meet fair tight tolerances leading them to meet the same minimum level of quality and requirements. Anything above that level is gravy that's probably turd polishing for all intents and purposes.
Oils without an API cert, well you can believe their crap shoot info if you want. I always wonder why they won't certify.
[Re: Luis Zavala]
#2548809
09/11/18 03:02 PM
09/11/18 03:02 PM
Supercuda
About to go away
About to go away
up yours
Lots of Amsoil stuff doesn't have API cert
Cue fanboyz
