G3 rocker arms
#2547261
09/07/18 04:41 PM
09/07/18 04:41 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
So Jesel just cam out with a rocker set up that uses the stock rocker pads like the TD. Intakes ratio is 1.80 Ex is 1.85 Comes with shafts. These are for the Dragpak cars? Now before you read any further grab a seat......... They are 250.00 a rocker ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) Part # are as follows EX = IRA-127210EA185 INT = IRA-127210IA180 This is the info given to me over the phone.
Re: G3 rocker arms
[Re: MattW]
#2547305
09/07/18 06:42 PM
09/07/18 06:42 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
The ratio change is interesting. I assume these are adjustable roller tip? Roller bearing or bushed?
Price US $ ?
"Just a Bracket car dressed up like a streetcar"
Re: G3 rocker arms
[Re: MattW]
#2548264
09/10/18 09:15 AM
09/10/18 09:15 AM
Posts: 625 Indianapolis In. usa
Quickrunner
Manton pushrods is just coming out with a nice set too. It's on their FB, about a grand cheaper but still spendy.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: G3 rocker arms
[Re: LA360]
#2548671
09/11/18 09:00 AM
09/11/18 09:00 AM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
Investment casting would probably be the most economical way to make them I would imagine This. I also spoke to a gentleman from Diversified Creations (the people who bought out Arrington) and they are reworking the rockers that Arrington offered and hope to have them out by the end of the year.
Re: G3 rocker arms
[Re: fbs63]
#2548683
09/11/18 10:31 AM
09/11/18 10:31 AM
Posts: 3,874 Smyrna, South Carolina
STEFF
Investment casting would probably be the most economical way to make them I would imagine This. I also spoke to a gentleman from Diversified Creations (the people who bought out Arrington) and they are reworking the rockers that Arrington offered and hope to have them out by the end of the year. Arrington's Rockers were non adjustable. Not sure on the investment castings versus machining from billet, from a strength perspective.
Re: G3 rocker arms
[Re: STEFF]
#2549241
09/12/18 03:26 PM
09/12/18 03:26 PM
dogdays
I believe Norris stainless steel rockers were investment cast. That's also known as "lost wax casting".\ Strength depends on the material. If one is comparing cast iron to forged steel the answer is obvious. However, if one is comparing a forging or billet piece of say 17-4 ph to an investment casting of the same material it would surprise you how close the strengths are. One reason investment casting is mentioned at all is that it provides a near net shape with little machining required. Thus the investment cast rocker might cost quite a bit less. https://www.milwaukeeprec.com/investment-casting-benefits.htmlR.
Re: G3 rocker arms
[Re: WO23Coronet]
#2638326
03/29/19 01:49 AM
03/29/19 01:49 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
My gen2 StageV rockers were only $1600...and those are stainless...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: G3 rocker arms
[Re: astjp2]
#2638612
03/29/19 09:12 PM
03/29/19 09:12 PM
Posts: 4,255 Canada
WO23Coronet
Canada
My gen2 StageV rockers were only $1600...and those are stainless... That’s great, but your blocks are 6K+ and heads 3K+ (Minimum). Lots of guys run the stock Gen III stuff to 7500 rpm
