Re: 470 build
[Re: Wedgeman]
#2547537
09/08/18 11:41 AM
09/08/18 11:41 AM
Posts: 1,051 The Great White North
RAMM
Using the 6.700 rods with a 3.9 stroke....do I need to notch the cylinder for rod clearance ? Maybe maybe not--How would we know? We don't know what kind of rods you have in front of you. Mock it up and check--its called ENGINE BUILDING. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: 470 build
[Re: AndyF]
#2547543
09/08/18 11:53 AM
09/08/18 11:53 AM
RAMM
Search for 470 and you'll find dozens of threads on this board. The 470 is one of my all time fave big block builds and I love big blocks for various reasons. Unless OP has a machine shop at his disposal, I would call 440 Source and just order one of their 470 kits, have my block machined with the "full meal deal" and stick any of the larger solid lifter variety cams in it. Depending on the "fully ported" Eddy heads power will be healthy and torque will be almost 100 ft/lbs greater than a 408. Single biggest gripe I have is the down right horrible valve position. When you "fix" that expect major power improvements. Oh and now I am deathly afraid of rear main leaks although the last few have been bone dry. J.Rob
Re: 470 build
[Re: Wedgeman]
#2547688
09/08/18 08:47 PM
09/08/18 08:47 PM
Posts: 4,206 New York
polyspheric
New York
I beam less likely to nick the wall than H beam. Rod side clearance is safe at any figure you're going to get (over .014" or so, my preference), except: does this allow the piston pin boss to strike the rod eye? Not likely, but check each one separately. If the boss width is more than .060" smaller than the eye width and the boss is symmetrical you're probably safe.
Boffin Emeritus
Re: 470 build
[Re: Wedgeman]
#2547696
09/08/18 09:11 PM
09/08/18 09:11 PM
Posts: 2,141 junction city oregon
viperblue72
Using the 6.700 rods with a 3.9 stroke....do I need to notch the cylinder for rod clearance ? I didn’t even need to notch the bores with a 4.25 stroke so I don’t see how you would have any clearance issues. I did have to take off just a bit at the oil pickup boss, which was only a few seconds with a grinder.
Re: 470 build
[Re: RAMM]
#2547716
09/08/18 10:08 PM
09/08/18 10:08 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Search for 470 and you'll find dozens of threads on this board. The 470 is one of my all time fave big block builds and I love big blocks for various reasons. Unless OP has a machine shop at his disposal, I would call 440 Source and just order one of their 470 kits, have my block machined with the "full meal deal" and stick any of the larger solid lifter variety cams in it. Depending on the "fully ported" Eddy heads power will be healthy and torque will be almost 100 ft/lbs greater than a 408. Single biggest gripe I have is the down right horrible valve position. When you "fix" that expect major power improvements. Oh and now I am deathly afraid of rear main leaks although the last few have been bone dry. J.Rob What do you mean by ''the down right horrible valve position'' ? Please explain.... I may repeat myself, but I never hear of details like, single pattern camshaft is good or better or you need more duration on exhaust or lobes that are different...Eddy heads need more duration that Indy's and so on...I have so much a hard time choosing parts for me and so easy build for others......may be because I know there is so much to learn here.... The more I learn, the more I know I don't know much... Where are you located ? Dan
