Re: Locked timing on a street/strip car
[Re: 70Drop]
#2546454
09/05/18 11:44 PM
09/05/18 11:44 PM
Posts: 4,206 New York
polyspheric
New York
Fixed timing is best, because every engine needs the exact same spark under all conditions.
Boffin Emeritus
[Re: polyspheric]
#2546458
09/05/18 11:49 PM
09/05/18 11:49 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I just don't understand why you would need to lock it out on a street/strip car I mean will it gain any performance? I set my base at 23 and total at 34 all in by 1800 RPM and it runs perfect with my combo. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 70Drop]
#2546487
09/06/18 12:41 AM
09/06/18 12:41 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
There is a need for a timing curve, especially street cars. It wouldn't be a good idea to lock it out. There are points in time when the engine could use less than maximum high speed timing.
[image][/image]
[Re: 70Drop]
#2546499
09/06/18 01:03 AM
09/06/18 01:03 AM
Posts: 11,542 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
24 base with 36 total. Big cam, not much manifold vacuum. What RPM are you able to get the thing to idle at? In gear? Drilled throttle blades or the throttle opened way up? If its all in by 1500 or 1800, why bother with idle problems?
I can lock it out, set the throttle blades where they're supposed to be in relation to the transfer slots, make it idle at 800 in gear with a big flat tappet or roller, great throttle response, runs great. Timing is rock steady at any speed rather than chasing the base around at idle with light springs. What am I doing wrong?
[Re: 70Drop]
#2546521
09/06/18 01:43 AM
09/06/18 01:43 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The car idles fine. That's not an issue. The reason I'm thinking about it is 1) I like simplicity on my cars 2) Locked timing will allow me to run a crank trigger. I love the precision of crank triggers. I cringe when I see timing flutter at WOT. Every car I've had has done a little bit of that. Even just a degree or two bothers me! If you shimmed the dist shaft you wouldnt see any flutter
[Re: MR_P_BODY]
#2546527
09/06/18 02:31 AM
09/06/18 02:31 AM
Posts: 223 California
70Drop
California
The car idles fine. That's not an issue. The reason I'm thinking about it is 1) I like simplicity on my cars 2) Locked timing will allow me to run a crank trigger. I love the precision of crank triggers. I cringe when I see timing flutter at WOT. Every car I've had has done a little bit of that. Even just a degree or two bothers me! If you shimmed the dist shaft you wouldnt see any flutter I have a collar on the shaft that fits tight up against the drive gear. Is that the play you're talking about controlling? I've never shimmed a shaft before
[Re: CMcAllister]
#2546543
09/06/18 05:06 AM
09/06/18 05:06 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I can lock it out, set the throttle blades where they're supposed to be in relation to the transfer slots, make it idle at 800 in gear with a big flat tappet or roller, great throttle response, runs great. Timing is rock steady at any speed rather than chasing the base around at idle with light springs. What am I doing wrong? I don't see anything wrong. I use light springs in my dist that has full advance all in by 1800 rpm. Basically I set my total at 36 as that's what my car seems to like best and let the initial fall where it does. Which on my car its got around 24 degrees at idle in park. It runs great like that and has no ping at all on 92 pump. I see some guys run locked out timing on their cars but I never have. But to be honest when you think about it the setup we run and guys like Gus which his sounds about like mine is not all that far from being locked out. Course we don't have to much timing when cranking the eng but once its running and we hit the gas we are almost at total timing right after hitting the gas pedal some. I like the ight springs all in by 1800 to 2000 rpm as it works nicely on my street driven car. Ron
[Re: 70Drop]
#2546568
09/06/18 09:28 AM
09/06/18 09:28 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I ran locked timing on my 11:1 360 on the street for years with zero trouble.
68 Barracuda Formula S 340
[Re: CMcAllister]
#2546595
09/06/18 10:38 AM
09/06/18 10:38 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I can lock it out, set the throttle blades where they're supposed to be in relation to the transfer slots, make it idle at 800 in gear with a big flat tappet or roller, great throttle response, runs great. Timing is rock steady at any speed rather than chasing the base around at idle with light springs. What am I doing wrong? Like Dwayne said, you're not doing anything wrong. Locking it out works better as the engine gets wilder. Nothing wrong at all doing it on a street driven car. For a mild engine it may not have as much benefit. No need for a start retard either...don't use it. Crank triggers are so nice when setting the timing, the mark is rock steady.
[Re: fourgearsavoy]
#2546600
09/06/18 10:55 AM
09/06/18 10:55 AM
Posts: 4,669 Wichita
GY3
Wichita
I just don't understand why you would need to lock it out on a street/strip car I mean will it gain any performance? I set my base at 23 and total at 34 all in by 1800 RPM and it runs perfect with my combo. Gus Pretty much the same here.
[Re: GY3]
#2546608
09/06/18 11:15 AM
09/06/18 11:15 AM
an8sec70cuda
I just don't understand why you would need to lock it out on a street/strip car I mean will it gain any performance? I set my base at 23 and total at 34 all in by 1800 RPM and it runs perfect with my combo. Gus Pretty much the same here. So how much time do you think your engine spends under 1800 rpm on the street? Other than idling. I don't see the need for the advance.
[Re: 70Drop]
#2546609
09/06/18 11:16 AM
09/06/18 11:16 AM
Posts: 4,457 Washington
madscientist
Washington
The car idles fine. That's not an issue. The reason I'm thinking about it is 1) I like simplicity on my cars 2) Locked timing will allow me to run a crank trigger. I love the precision of crank triggers. I cringe when I see timing flutter at WOT. Every car I've had has done a little bit of that. Even just a degree or two bothers me! If you shimmed the dist shaft you wouldnt see any flutter I have a collar on the shaft that fits tight up against the drive gear. Is that the play you're talking about controlling? I've never shimmed a shaft before I think Mr Pbody is talking about shimming the distributor itself. Some of the stuff I've seen had .080-.090 slop in the distributor. On the dyno with a customer supplied MSD that was wacky. It had .100 clearance. Shimmed it to where it had about .010 and it was golden.
[Re: 70Drop]
#2546625
09/06/18 12:13 PM
09/06/18 12:13 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
So, you’ve got your big lumpy cam and the accompanying super low vacuum, low gears, and a high stall converter. You keep bumping up the initial timing and discover the vacuum goes up, throttle response gets better, idle circuit in the carb becomes more responsive. You bump up the initial more, and get more of the same improvements.
As Chip said, if the combo is “wild” enough, you keep bumping up the initial, and limiting the sweep to keep the total where you want it....... and eventually you find there is no sweep anymore.
That’s how I came to it over 30 years ago........by making adjustments, driving the car and seeing if it ran/drove better or not. More initial did everything better....... so I kept sneaking up on it....... more driving, more evaluating....... until there was essentially no “curve” left. For the last curve I was at 30 initial/36 total, all in by 2200. I locked out another distributor, swapped it out...... and it was marginally better, so I left it like that.
[Re: an8sec70cuda]
#2546628
09/06/18 12:21 PM
09/06/18 12:21 PM
GY3
Wichita
I just don't understand why you would need to lock it out on a street/strip car I mean will it gain any performance? I set my base at 23 and total at 34 all in by 1800 RPM and it runs perfect with my combo. Gus Pretty much the same here. So how much time do you think your engine spends under 1800 rpm on the street? Other than idling. I don't see the need for the advance. Very little. The reason mine is setup this way is to make sure it starts easy. 99% of the time it is at full advance.
