Re: Carb CFM
[Re: 1970RT]
#2546566
09/06/18 08:40 AM
09/06/18 08:40 AM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
The 750 you have should work fine. Rather than buying another carb invest in a A/F meter and a tuning kit for your Edelbrock. If you really have to buy a carb a 850 Thermoquad will give you the best of both worlds IF you tune it properly.
Re: Carb CFM
[Re: J_BODY]
#2546599
09/06/18 10:54 AM
09/06/18 10:54 AM
Posts: 3,916 usa
lewtot184
usa
i don't get lost in cfm ratings and don't use them as a major criteria for carb(s) selection. i'm old school and still look at venturi area. So how much would a 1.48 venturi 1.79 throttle blade carb support..... asking for a friend not to be a smart a$$ but it really depends. the numbers you gave are odd. what carb is this?
Re: Carb CFM
[Re: lewtot184]
#2546603
09/06/18 11:05 AM
09/06/18 11:05 AM
BradH
i don't get lost in cfm ratings and don't use them as a major criteria for carb(s) selection. i'm old school and still look at venturi area. So how much would a 1.48 venturi 1.79 throttle blade carb support..... asking for a friend not to be a smart a$$ but it really depends. the numbers you gave are odd. what carb is this? Must be a Braswell 4825... Is it a 2-circuit or 4-circuit?
