Re: Magnum V-8 with early distributor, phazing question..... [Re: SKR8PN] #2544252
09/01/18 01:39 PM
09/01/18 01:39 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have had good luck with the MSD blaster 2 coil.
Re: Magnum V-8 with early distributor, phazing question..... [Re: RapidRobert] #2544255
09/01/18 01:42 PM
09/01/18 01:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By RapidRobert
it will shift RP cuz the tooth reaches the magnet sooner so when it fires the rotor is now at a different clocking.
You realize you just said it changes the phasing, which is the relationship of the rotor to the cap, not the rotor to the reluctor.
Don't be the exception.
Re: Magnum V-8 with early distributor, phazing question..... [Re: Supercuda] #2544270
09/01/18 02:23 PM
09/01/18 02:23 PM
Agreed, yes it (vac adv) changes RP (rotor to cap) & not rotor to reluctor (that is fixed on the shaft). EDIT I reread my prior above long post & I had said "WOULD" & I meant to say "WOULD NOT" so I changed it to reflect what I intended to say.
Re: Magnum V-8 with early distributor, phazing question..... [Re: RapidRobert] #2544613
09/02/18 01:29 PM
09/02/18 01:29 PM
moparx Offline
moparx  Offline
when drilling the hole in the cap, use a "unibit" style step drill to the size hole you want/need. using a regular flute style of drill can catch and spall out the back side of the hole, or crack a chunk of the cap out. the step drill won't do this. just a helpful tip.
beer
Re: Magnum V-8 with early distributor, phazing question..... [Re: moparx] #2544741
09/02/18 05:42 PM
09/02/18 05:42 PM
^^^ noted
