Re: To much flow ? Not enough Velocity
[Re: 70dusterjohn]
#2545336
09/03/18 08:45 PM
09/03/18 08:45 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I would try that new converter next and take a known good carb with you off someone else's car. That will eliminate 2 big possibilities and hopefully fix the problem. Try the carb after you make a run with the new converter obviously.
