Why not round ports?
#2542085
08/27/18 05:16 PM
08/27/18 05:16 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Why does it seem all ports even super serious max effort unlimited buget, are either rectangle oval square... but never a perfectly round port? Seems with the biggest cross section VS surface area it would make the most flow... just curious what I am missing there.
And while I am wondering hypothetical curiosity stuff why not header style intake mainifolds like toyota corllas? With modern MPI it seems the problems of the long ram BBs fuel pudling/dropout would be long gone...
Re: Why not round ports?
[Re: HotRodDave]
#2542141
08/27/18 08:06 PM
08/27/18 08:06 PM
Posts: 20,205 Park Forest, IL
slantzilla
Park Forest, IL
Ford did big round ports on the Tunnel Port 427. They didn't seem to catch on.
[Re: AndyF]
#2542155
08/27/18 08:47 PM
08/27/18 08:47 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I think like Andy said port area becomes an issue. I know Al M has posted pictures a few times of his oval port B1 heads and they put out some nice numbers.
[Re: HotRodDave]
#2542311
08/28/18 02:28 AM
08/28/18 02:28 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Think about a round layout in a head.... with 4 ports in a single casting; round next to round, you’re giving away a lot of available space that could be flowing air, and instead is carrying weight.
[Re: HotRodDave]
#2542322
08/28/18 04:54 AM
08/28/18 04:54 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
There all fluids, correct, air or liquid Think about water flowing down a drain tube or toilet, doesn't it swirl as it enters the smaller part of the tube, venture, or exit That being said every production 460 Ford head and 351 C motors had round ports in them, correct
[Re: HotRodDave]
#2542564
08/28/18 03:49 PM
08/28/18 03:49 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
From the web:
"Big-block enthusiasts have always looked down their noses at oval-ports, but we’re here to tell you that round is the new square. As a general rule, round (or oval) ports will outflow their rectangular counterpart given equal dimensional area. The reason is that the corners of a rectangle are actually wasted space in terms of flow. The flow rate in the corners is very limited, so the wasted space does little more than increase port volume. This is obviously not a desirable situation, as power production is a product of both airflow and volume. The ideal situation (for most street/strip motors) is to maximize flow while minimizing port volume. There’s an argument to be made for increased port volume on high-rpm (dedicated) race motors, but for most, small port and big flow is the best combination."
[Re: HotRodDave]
#2542584
08/28/18 04:23 PM
08/28/18 04:23 PM
Posts: 3,505 DFW
mr_340
DFW
Kinda, sorta round if you remove the fins (to meet a volume spec for NHRA).
Floyd Lippencott IV
[Re: HotRodDave]
#2543596
08/30/18 09:04 PM
08/30/18 09:04 PM
Posts: 4,210 New York
polyspheric
New York
As a general rule, round (or oval) ports will outflow their rectangular counterpart given equal dimensional area. Or, not.
If it was that obvious, why do those idiots continue to design ports in other shapes? Because the port is NOT STRAIGHT.
Boffin Emeritus
