"The Block" - Such a pretty sight...........
#2541665
08/26/18 06:30 PM
08/26/18 06:30 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
After disassembling the short block due to issues, my motor is done!
Its a new "The Block" RB 505 with Trick Flow 270 heads, 337 intake and one of Dwayne's solid roller cams. Its for my 69 GTX street/strip new build.
Should hit the dyno next week. Hopefully the power numbers won't disappoint.
PS - I hate computers. The picture is not sideways on my computer.
Re: "The Block" - Such a pretty sight...........
[Re: markz528]
#2541688
08/26/18 07:26 PM
08/26/18 07:26 PM
Posts: 2,459 Sydney,Australia
tex013
Sydney,Australia
Argh if only I could get 1 of these ! I would buy 1 in a flash What sort of issues ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: sgcuda]
#2541693
08/26/18 07:40 PM
08/26/18 07:40 PM
markz528
Morrow, OH
Its the new "The Block" made by the fellow from Chicago Connection with a bunch of other fingers in the pot......... Issues included: Cam would not go in - the cam bearing bores are tight Dipstick hole too tight Lifter bores - let's just say they were no good Distributor gear drive would not go in - gear was hitting the block Minor clearance issues on some oil plugs Tony Bischoff (BES) fixed it and assembled the motor. He is good and knows how to make power.
[Re: BigBlockMopar]
#2541726
08/26/18 08:22 PM
08/26/18 08:22 PM
markz528
Morrow, OH
I'm in work - W10 screws me up. I will fix my pic with my W7 machine when I get home.
[Re: markz528]
#2541964
08/27/18 12:09 PM
08/27/18 12:09 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looks good....... but I would have gone in a different direction for the block color😉
Are you going to use the car headers, or do they have dyno headers? Just wondering what size will be used for testing.
Did they do any more to the manifold besides port matching?
[Re: markz528]
#2541966
08/27/18 12:11 PM
08/27/18 12:11 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Nice! Hope it works out good on the dyno!
Never understood why someone would completely assemble an engine like that when the block needs painting...considering most don't want to paint brand new aluminum heads, new balancer, etc.
[Re: R3 Racing]
#2541978
08/27/18 12:25 PM
08/27/18 12:25 PM
an8sec70cuda
You must not know Mark. When that thing is done and in the car, it will look a piece of jewelry. Mark invented the word "anal". I didn't mean the owner, he said BES built it and I've seen many other engine builders do this. Just adds a lot of time masking off and prepping for paint.
[Re: an8sec70cuda]
#2542048
08/27/18 03:23 PM
08/27/18 03:23 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I paint all my motors after they are assembled and ready to go (lots of cleaning solvent and brake cleaning solvents used to remove any oil or grease) and before dyno testing them What's a little time and effort masking them worth
[Re: markz528]
#2542056
08/27/18 03:34 PM
08/27/18 03:34 PM
an8sec70cuda
I paint the shortblock before all the pretty stuff gets bolted on. Sorry for the post hi-jack markz528, I'm sure that's gonna be a good runnin engine! Glad to see someone who actually has their hands on one of these blocks.
[Re: fast68plymouth]
#2542226
08/27/18 11:10 PM
08/27/18 11:10 PM
markz528
Morrow, OH
Did they do any more to the manifold besides port matching? Y'all don't like my primer color????? It's gonna be orange. Am I crazy for wanting to paint the heads? Might start a separate thread for that question. BES asked if I wanted it painted - nope. If it leaks I want to fix the leaks before it gets painted. I can tape with the best of them....... I hope to use my headers but if they won't work with the dyno they have headers. My headers are Hooker 2 inch 5209's - same as I run in the race car. They basically port matched the intake - but they got opened up quite a bit. No additional work was done to the intake. Thanks Ron - Monte Smith used to call me anal also...........
[Re: MR_P_BODY]
#2542228
08/27/18 11:11 PM
08/27/18 11:11 PM
markz528
Morrow, OH
Whos breathers are those.. I like them.. the engine looks good also K&N Bought a long time ago............
[Re: markz528]
#2542230
08/27/18 11:13 PM
08/27/18 11:13 PM
fast68plymouth
So. Burlington, Vt.
5209’s have worked on the dyno for me....... they will likely be able to use them.
[Re: markz528]
#2543674
08/31/18 01:25 AM
08/31/18 01:25 AM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Nice looking build you have there. Please be sure to post updates as you get through the dyno and into the car.
I wish I knew Monte well enough to have had him call me anal ... RIP buddy
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
