Re: 1939 Dodge 89 dakota chassis swap and V6 or 5.2
[Re: wannadrag]
#2541841
08/27/18 01:09 AM
08/27/18 01:09 AM
moparpollack
Lil Herman
Lil Herman
85086
I started with a 4 cylinder truck and then made mounts for a set of spool mounts I had laying around for a 360. Files are to big for here so I could email you mine if you would like.
[Re: wannadrag]
#2542795
08/28/18 11:10 PM
08/28/18 11:10 PM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
How much did you pay for the truck??? Probably not. The Hot Wire harness isn't cheap, but by the time to get an intake, a new carb, a distributor, and fuel pump that will work for the carb, the Hot Wire harness is probably comparable. www.hotwireauto.com You could resource a 5.2 harness out of a 92-96 5.2 Dakota, there is info right here on Moparts on how to modify that harness. Gene
