Re: M/P HEMI BLOCKS
[Re: 440lebaron]
#2561625
10/09/18 10:08 PM
10/09/18 10:08 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I haven't received anything since the initial order confirmation. On my order status page on their website it only says backordered.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: M/P HEMI BLOCKS
[Re: Hemi_Joel]
#2563455
10/13/18 04:42 PM
10/13/18 04:42 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
The two blocks i got from mopar last month were cast at dalton foundry which would mean the were old castings, so the rumor must of been true that mopar had 150 left over blocks that needed machining. Tag on crate said "job 122 of 150" Gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: M/P HEMI BLOCKS
[Re: boomerodell]
#2563769
10/14/18 10:25 AM
10/14/18 10:25 AM
Posts: 6,435 Abilene, Texas
fastmark
Abilene, Texas
Ive been watching this thread for awhile and finally decided to chime in. The 4.5 bore block I received in April states Hemi #5 of 17 on crate with the current mopar pn however DOES appear to have been in a warehouse for quite some time. When you say it appears to have been in a warehouse, do you mean some of the machined surfaces look they have been done for awhile? Did you guys get these blocks from a local Mopar dealers?
Re: M/P HEMI BLOCKS
[Re: 440lebaron]
#2565485
10/17/18 05:57 PM
10/17/18 05:57 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Any opinions on buying one and converting it to a wedge? I'm aware of the details of conversion and since there's no wedge blocks this seems like a good option.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
Re: M/P HEMI BLOCKS
[Re: Jamey]
#2565959
10/18/18 02:56 PM
10/18/18 02:56 PM
d7cook
Cincinnati, Ohio
Well I went ahead and ordered one. If I get it I'll see how much effort is to convert to a wedge. If I don't convert it I'll just put in the corner and build it in my elderly years.
Re: M/P HEMI BLOCKS
[Re: fastmark]
#2570698
10/28/18 08:08 PM
10/28/18 08:08 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
Ive been watching this thread for awhile and finally decided to chime in. The 4.5 bore block I received in April states Hemi #5 of 17 on crate with the current mopar pn however DOES appear to have been in a warehouse for quite some time. When you say it appears to have been in a warehouse, do you mean some of the machined surfaces look they have been done for awhile? Did you guys get these blocks from a local Mopar dealers? It seems they are trickle feeding these blocks out as they can machine them. Dealers themselves don't get any clear communication on block production scheduling. A tip to anyone receiving one of these blocks check the quality of the machining immediately. I was meeting with one of our dealers last week who received a MP cast iron HEMI block that had pushrod notches machined so close the the cylinder bores that a head gasket will never seal it. It is not possible to adequately repair machining errors in critical areas like this. If you don't get back to MP within the 30 day limited warranty period it's tough luck. Be sure to check this.
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: M/P HEMI BLOCKS
[Re: Keith Black®]
#2570872
10/29/18 09:22 AM
10/29/18 09:22 AM
fastmark
Abilene, Texas
Ive been watching this thread for awhile and finally decided to chime in. The 4.5 bore block I received in April states Hemi #5 of 17 on crate with the current mopar pn however DOES appear to have been in a warehouse for quite some time. When you say it appears to have been in a warehouse, do you mean some of the machined surfaces look they have been done for awhile? Did you guys get these blocks from a local Mopar dealers? It seems they are trickle feeding these blocks out as they can machine them. Dealers themselves don't get any clear communication on block production scheduling. A tip to anyone receiving one of these blocks check the quality of the machining immediately. I was meeting with one of our dealers last week who received a MP cast iron HEMI block that had pushrod notches machined so close the the cylinder bores that a head gasket will never seal it. It is not possible to adequately repair machining errors in critical areas like this. If you don't get back to MP within the 30 day limited warranty period it's tough luck. Be sure to check this. My thoughts axactly. Anyone ordering one of these blocks for future value needs to be wary that it might be an expensive boat anchor. It appears that these are leftover world castings that got pulled from machining process when the problems came between the parties. I’m sure the new guys were the cheapest bid and probably started from scratch.
Re: M/P HEMI BLOCKS
[Re: 440lebaron]
#2570943
10/29/18 12:26 PM
10/29/18 12:26 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
Got a report recently from a dealer in CA, he received one that he'd had on backorder for a couple years.
Rich H.
Esse Quam Videri
Re: M/P HEMI BLOCKS
[Re: Craig J]
#2574756
11/06/18 11:13 AM
11/06/18 11:13 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Well... Nov 5 passed with no update from Jegs.
Tomorrow I will probably just cancel my order. Anyone here have 1st hand experience with BMP aluminum hemi blocks?
Thanks Craig I had one of the older Hemi blocks. I have one of the older wedge blocks too. Both are and were good blocks.
Re: M/P HEMI BLOCKS
[Re: Craig J]
#2574783
11/06/18 12:26 PM
11/06/18 12:26 PM
Posts: 2,686 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Thanks Craig Don't give up so easily.
2011 Drag Pak Challenger
Re: M/P HEMI BLOCKS
[Re: rickseeman]
#2574836
11/06/18 01:56 PM
11/06/18 01:56 PM
ZIPPY
S.E. Michigan
Thanks Craig Don't give up so easily. I agree. Or, if you're going to quit Jegs, then quit and try a Chrysler dealer. Jegs is cool and all, I like 'em other than the time they used Yellow Freight to deliver my roll bar kit (long story)....but unless they've changed their purchasing practice, they only place orders with Chrysler at certain intervals. It's usually a long time between orders. Your backorder could still be sitting in jegs' system and not even placed with Chrysler yet.
Rich H.
Esse Quam Videri
Re: M/P HEMI BLOCKS
[Re: rickseeman]
#2575415
11/07/18 04:25 PM
11/07/18 04:25 PM
d7cook
Cincinnati, Ohio
Now Jeg's says February. I went ahead and canceled my order. Between the wait, the questionable quality and the work involved in converting to a wedge I decided to leave the victor headed motor project on the shelf for now.
