Re: very sad 440-6
[Re: 440newport]
#254083
03/15/09 04:24 PM
03/15/09 04:24 PM
I agree but I just talked to Summit Racing and they said get the car running and start feeling different ignition parts for getting hot. The second I touched the plug on the modual on the fire wall the car quit. I restarted the car and wiggled the plug lightly again and the car quit. Still under warrantee and they are sending me a new assembly, I am hoping that is the problem, what do you think.
Re: very sad 440-6
[Re: stumpy]
#254085
03/15/09 04:36 PM
03/15/09 04:36 PM
yes made sure and double checked, I think it is with the three terminals that the plug plugs into
Re: very sad 440-6
[Re: 1fastrunner]
#254088
03/15/09 05:40 PM
03/15/09 05:40 PM
it does and I am going to replace the balaster, modual, and distributor. Summit Racing was kind enough to send all new parts tomorrow. I am really thinking this is the problem
Re: very sad 440-6
[Re: dodger1]
#254091
03/15/09 09:02 PM
03/15/09 09:02 PM
I really think it is the ignition modual on the firewall at this point. I have checked the fuel level so many times and each time it is right where it should be.
Re: very sad 440-6
#254092
03/15/09 09:39 PM
03/15/09 09:39 PM
Posts: 2,937 GA
roadrunninMark
GA
Try this.. after car is hot and then stalls, plug a spark plug and ground the tip on the body. Crank it over and see if you have spark. No spark means you can eliminate the fuel system and problem is in the electrical/ignition. For an electrical issue, try this...after running for a little while, take the negative battery cable off while engine is running. If car stalls immediately, have your alternator looked at. What is the volts in the battery after it stalls? If not over 12 then alternator is prob. bad too
If peeps already mentioned these, forgive my remittance.
