Distributor advance q’s. #2539182
08/20/18 06:16 PM
08/20/18 06:16 PM
junction city oregon
V
viperblue72 Offline OP
V
I bought a new distributor for my newish motor and want it curved. My engine builder asked me how I want it curved. At that point I realized I don’t have a complete understanding of what I should do. I know cam duration and timing has an effect.
I want my car to start easy but the more I advance the easier it starts although it starts to work against itself as well. Just thought I’d ask advice here and see what I can learn.
Re: Distributor advance q’s. [Re: viperblue72] #2539185
08/20/18 06:19 PM
08/20/18 06:19 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
So @ what RPM do you want your timing to be at full advance??
Re: Distributor advance q’s. [Re: viperblue72] #2539218
08/20/18 07:49 PM
08/20/18 07:49 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind
Boffin Emeritus
Re: Distributor advance q’s. [Re: viperblue72] #2539254
08/20/18 08:45 PM
08/20/18 08:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
So motor specs, cam specs, Torque converter specs, where is cam degreed are all nice to know. headers, intake carb and such.
Looked up your other posts and with 511 and 274 @ .050 I would put light mister gasket springs in to have it all in by 1000 or 1200. No vacuum Advance.
Re: Distributor advance q’s. [Re: viperblue72] #2539399
08/21/18 01:36 AM
08/21/18 01:36 AM
(1) set the initial with the "vac gauge method" then (2) buy/use the $25 FBO plate to limit the total (initial+slots) to the "std" for your eng (35-sb) which will get somewhat "close" then (3) mix/match springs so you are just under the pinging point at WOT up thru the gears on your hottest/driest(most likely to ping) day then (4) plug in the can to ported & adj it so you are just under the pinging point in everyday driving under varying RPM/load conditions & adj it (slope not the total) with the hex wrench. Peoples' hearing varies & there is "silent" ping so give it a cushion. "manifold" porting for the can is touted by many people & locked out timing has its place. Bottom line: NO pinging, you want to get "somewhat" close that line but never over it. Any combo of springs (except for the OE heavy spring with the elongated loop) advance in a linear rate so any combo of chebby or transdapt or mr gasket or MP springs are OK to get your ideal combo.
Re: Distributor advance q’s. [Re: viperblue72] #2539409
08/21/18 02:27 AM
08/21/18 02:27 AM
AndyF Offline
AndyF  Offline
Depends on the distributor and how much time you're willing to pay for. If it is a MSD billet then there is a selection of springs and bushings. The instructions show you the different curves so you just pick it out and install it. If you have an older Mopar distributor then you're kind of up a creek if you want to dial it in. Back in the old days people would braze up the slots and file them to size and all of that jazz. If you have a modern digital distributor then you can set the curve by just turning the dials.
Re: Distributor advance q’s. [Re: viperblue72] #2539450
08/21/18 08:12 AM
08/21/18 08:12 AM
crabman173
crabman173
80% of units with MSD can start with black stop bushing and one light silver , one light blue spring and be right on The way they send them out the door they are almost unusable Also spray WD40 on the reluctor --they are some odd metal and will corrode making unbelievable mess-- stopping you in the middle of the road
FBO plate should get Mopar product of the decade--awesome problem solver backed by a smart patient guy Wish I had invented it
Re: Distributor advance q’s. [Re: viperblue72] #2539558
08/21/18 01:35 PM
08/21/18 01:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If it’s a race car, I’d start out with it locked.
If it doesn’t fight the starter when it’s hot...... you’re done.
Re: Distributor advance q’s. [Re: viperblue72] #2539560
08/21/18 01:39 PM
08/21/18 01:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you set the advance so you have between 14 to 18 BTDC idling with 34 to 36 total above 2000 RPM it should fly up scope
Re: Distributor advance q’s. [Re: viperblue72] #2539565
08/21/18 01:46 PM
08/21/18 01:46 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
proper advance curve depends on a lot of variables, I use performance trends engine software, it will plot an advance curve for your engine, then use a distributor machine or a timing light and have a buddy hold the throttle at different rpm's and plot the results, swap springs and weights until its right. The program is relative cheap and it calculates a ton of other stuff.
http://performancetrends.com/Engine-Analyzer.htm
Re: Distributor advance q’s. [Re: viperblue72] #2539600
08/21/18 02:40 PM
08/21/18 02:40 PM
V
V
The distributor is a 440source. No vacuum advance.
Yes it’s 511
11.5 to 1
274@50
4800 stall
Will be 4.10 gear with 31” tire
Re: Distributor advance q’s. [Re: viperblue72] #2539603
08/21/18 02:45 PM
08/21/18 02:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If it were me I'd put these advance springs in and go!
https://www.summitracing.com/int/parts/mrg-925b
Re: Distributor advance q’s. [Re: fast68plymouth] #2539604
08/21/18 02:47 PM
08/21/18 02:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This is how we've been taught to do this but recently a buddy named William Baldwin has woken a few of us up to the fact that locked is not always the answer. There's a thing called "slew rate" which is the natural act of electronics retarding when you hit the gas and I've checked it on my Dart and sure enuff, the timing retards about 1 degree per 1000 rpm's.........NOT good people and I will be sending him a new MSD dizzy to "fix" for me and I will report back as to how it works...... beer
Re: Distributor advance q’s. [Re: viperblue72] #2539619
08/21/18 03:16 PM
08/21/18 03:16 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
with 274@50 - first I would dump that 440source dizzy and go with an MSD unit - but if budget demands use it but watch the internals as they have a tendency to destroy themselves after awhile. As far as a curve you will want about a 10 degree curve with all timing in by 1500 - 1800 RPM. The light weight mr gasket springs usually will get you there - if not drill the counter weights to lighten them up. another way is to lock it out and use a start retard function AKA msd starter saver or a digital 6 box
Re: Distributor advance q’s. [Re: Thumperdart] #2539633
08/21/18 03:46 PM
08/21/18 03:46 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yep and william answered one of my threads on timing curves stating all in by 5000rpm using the big factory springs with the loop. 10* curve starting at 26*@idle on my 511 with 11.25:1 comp using a 270@50 solid. He likes the factory distributors.
Re: Distributor advance q’s. [Re: mopar dave] #2539648
08/21/18 04:18 PM
08/21/18 04:18 PM
Washington
madscientist Offline
Washington
Does this guy have a web site or something?
Re: Distributor advance q’s. [Re: madscientist] #2539660
08/21/18 04:50 PM
08/21/18 04:50 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yep. Baldwin carbs.
Re: Distributor advance q’s. [Re: viperblue72] #2539665
08/21/18 05:00 PM
08/21/18 05:00 PM
Washington
Washington
Thanks MD
Re: Distributor advance q’s. [Re: madscientist] #2539683
08/21/18 05:29 PM
08/21/18 05:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FB Baldwin Performance Carburetors............. thumbs
Re: Distributor advance q’s. [Re: mopar dave] #2539685
08/21/18 05:31 PM
08/21/18 05:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Was going to have him do me up a stock unit but can't stand the male ends on the caps so MSD for me unless they make a male cap for Chrysler dizzy's........
