hydraulic clutch conversion without a kit #2538707
08/19/18 09:55 PM
08/19/18 09:55 PM
albemarle, NC
dusterbd13 Offline OP
albemarle, NC
since I have to pull the drivetrain out of my 70 duster due to a fragged clutch, I figure now is the perfect time to convert to hydraulic actuation.
im planning on a pull style 3/4 diameter slave, and would like to match with a wildwood remote reservoir 3/4 master. ideally, id like to use the factory holes in the firewall.
has anyone done this, and if so, how? id really like to avoid bespoke parts and 600 price tags in any way realistically possible.
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2538884
08/20/18 09:26 AM
08/20/18 09:26 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I did a similar swap on my desoto 318/833. I used a 3/4” master and a speedway motors 3/4” push slave. I was not able to get enough travel no matter what I did. I tried moving the slave mounting point further in on the clutch fork, but it still was not enough. I did drive the car for a while but knew the grinding was not good. I put an hydraulic throw out bearing(not the kit,just the bearing)in it and it worked much better. I welded a piece of sheet metal on the backside of the firewall for reinforcement and drilled/cut the holes for the master, after making a template of course.
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2538898
08/20/18 10:30 AM
08/20/18 10:30 AM
E
earlymopar Offline
earlymopar  Offline
E
A 3/4" master should normally have a 7/8" bore slave. Then it's just a matter of FULLY bleeding the slave and adjusting everything correctly from the pedal to the clutch arm and cylinder positions.
I've done the above on my Sweptline and simply made an adapter plate for the master cylinder that used the original firewall mounting holes for the OEM master cylinder (hole cutting and firewall mods are not usually needed). I made a bracket that bolts to the side of my transmission for mounting the slave cylinder.
- EM
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2538935
08/20/18 11:38 AM
08/20/18 11:38 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: hydraulic clutch conversion without a kit [Re: earlymopar] #2539024
08/20/18 01:57 PM
08/20/18 01:57 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
- EM
EM, I see you've highlighted the FULLY bleed portion of your post. Are there any tricks to getting the last bits of air out of these hydraulic systems. I have one and I believe I may have a small amount of air stuck in it. I've tried power bleeding, but it still feels like I may have some trapped air.
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2539036
08/20/18 02:15 PM
08/20/18 02:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The factory pulls a vacuum on them when they do a fill, Don't have to worry about bleeding out something that isn't there.
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2539099
08/20/18 03:49 PM
08/20/18 03:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you have a power brake booster, there isn't enough room to mount a clutch MC right next to the brake MC but, if you have standard brakes, the Wilwood MC can mount next to the brake MC.
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2539151
08/20/18 05:26 PM
08/20/18 05:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Take something like this
https://autoplicity.com/5372270-ams-auto...ingComNOFITMENT
adapt it to the stock pedal and make an adapter to match to the firewall. Remote the reservoir. Under $100 if you are handy.
Re: hydraulic clutch conversion without a kit [Re: jbc426] #2539268
08/20/18 09:35 PM
08/20/18 09:35 PM
E
earlymopar Offline
earlymopar  Offline
E
I think most of the common bleeding techniques and tools work. The only things I might add is to make sure the bleeder is on top of the cylinder as its mounted and to be persistent and keep at it. I started with gravity bleeding and then progressed on to vacuum bleeding each time making headway but often I find that just using the tube in a bottle of fluid and pushing the pedal works as a good final step.
- EM
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2539519
08/21/18 12:06 PM
08/21/18 12:06 PM
albemarle, NC
albemarle, NC
The thought of using a factory application master with a angled firewall mount has crossed my mind. Like a 4th gen camaro master.
Problem i run into is that theres very little bore information out there for these.
Re: hydraulic clutch conversion without a kit [Re: dusterbd13] #2539723
08/21/18 06:48 PM
08/21/18 06:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stuff I linked, 88 Fiero application
Clutch master, 11/16" bore
Clutch slave, 15/16"
4th Gen Camaro
Clutch master, 3/4" bore
Rockauto has the specs
Re: hydraulic clutch conversion without a kit [Re: Supercuda] #2541504
08/26/18 11:37 AM
08/26/18 11:37 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
On this Bigblockdart link. Does the rod come out of the slave straight like a suspension shock absorber or is it free to swivel with a ball joint after the piston?
