Turbo Action Shifter, strange issue #2538716
08/19/18 10:09 PM
08/19/18 10:09 PM
Tulsa OK
Bad340fish Online content OP
Bad340fish  Online Content OP
Tulsa OK
I am having a problem getting this transmission to adjust properly, the transmission I had in before was fine.
Turbo action shifter, cheetah valve body 904, same as the trans removed. All I changed was I added a CSR shield, and re-routed the shift cable, and beat the heck out of the floorpan. I can adjust the linkage where it engages each gear perfectly but will not engage park enough to work the neutral safety. The wheels will be locked(on jack stands) but it will not start. If I adjust to where it starts it will not go into high gear. This shifter has been in since 2010 with no troubles before.
I have another cheetah VB I could install, would that make the difference?
See the attached picture. In the pic the shifter is adjusted to fit the other gear positions perfectly, and the trans is fully engaged into park.
Thoughts?
68 Barracuda Formula S 340
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2538724
08/19/18 10:22 PM
08/19/18 10:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Have you adjusted it to neutral? That's how I adjust my JVX (Winters) shifter.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2538735
08/19/18 10:46 PM
08/19/18 10:46 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Mine works about 50% in Park. It works 100% in neutral so that's the backup plan. I'm not certain but it seems to me there are different length switches. You might also have a bad switch. I'd check the year the trans was built and get a switch for that year and compare to what you have. O'Reily and Autozone carry them. Some shifters have neutral switches built into them too. I don't use them as I like the tranny switch, it seems more durable and accurate!
Re: Turbo Action Shifter, strange issue [Re: humpty] #2538739
08/19/18 10:55 PM
08/19/18 10:55 PM
Tulsa OK
Tulsa OK
I have tried that yes, I can either adjust it to hit every gear perfectly but not park, or it can hit park and everything else is wrong.
I switched linkage and neutral switch with the other trans just to rule that out, no difference. I think I am going to pull the VB and compare it to another I have. I have three transmissions here and 4 cheetah VBs, i'll find something that works.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2538792
08/20/18 12:55 AM
08/20/18 12:55 AM
Tulsa OK
Tulsa OK
I tossed in an old VB I had that I am afraid to use. I put it in with no park rod and adjusted the shifter and everything worked. It started in both park and neutral and it adjusted right for high gear. I then swapped the 904 park rod onto my known good VB from my 727(that worked for 16 years, 8 of that with this shifter). Installed it, and it doesn't work. Is it possible this trans has the wrong park rod?
The VB I used that I got to adjust(with no park rod) has a different looking rooster comb than the other 2 VBs. I tried to swap it over and it doesn't work on what I assume are the newer VBs. It has a clearance issue with a plate on another part of the VB.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2538822
08/20/18 02:13 AM
08/20/18 02:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ll bite my tongue on your shifter choice and stay on point.... laugh2
FWIW a 904 park rod will measure 8” from the pin that fits in the valve body, to the end that fits in the pawl.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2538936
08/20/18 11:40 AM
08/20/18 11:40 AM
Tulsa OK
Tulsa OK
You know Jay when I went a new best 60ft a few weeks ago (1.437) I thought of you and wondered when it would start shifting itself into 2nd lol.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2538961
08/20/18 12:11 PM
08/20/18 12:11 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Ok, this sounds crazy but lots of lots of experience with the threaded stop nut style cables has showed me something I don't really understand.
Align the swivel exactly like the manufacturers instructions indicate. Now, do your adjusting at the cable end, not the swivel.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2539039
08/20/18 02:22 PM
08/20/18 02:22 PM
GEORGIA
barracuda7199 Offline
GEORGIA
I have had this issue before with a B&M shifter and fixed it by putting a washer between the shifter cable and shifter where the cable bolts to the shifter. If that makes any sense.
Re: Turbo Action Shifter, strange issue [Re: shorthorse] #2539041
08/20/18 02:25 PM
08/20/18 02:25 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I just fixed my buddy's car that had this issue for years. After adjusting to turbo action specs put additional 1 turn of the threaded pin towards park and try to start, his only took 1 turn, you might need more but I bet not much.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2539135
08/20/18 04:59 PM
08/20/18 04:59 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
My vote would be the park pawl is wrong.
Re: Turbo Action Shifter, strange issue [Re: shorthorse] #2539146
08/20/18 05:18 PM
08/20/18 05:18 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
This.
What you are dealing with is the point of reference. The point of reference being the coarse cable mounting adjustment. I have removed a transmission and just unbolted the cable mount bracket from the pan bolts. Did my transmission servicing, installed the same transmission in the same place and had this issue. There might be just enough slop in the mount holes to cause this issue to happen. Hope this helps.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2539165
08/20/18 05:52 PM
08/20/18 05:52 PM
Tulsa OK
Tulsa OK
I will definitely give some more attention to that bracket. I had extra brackets but I swapped the ones from the known good transmission during all this. I will move it around some tonight and see what I come up with.
I talked to Paul at Turbo Action and he said the 904 did have some different park rods in the early transmissions but they were pretty rare. I have one more 904 I can take apart to rob the park rod from.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2539199
08/20/18 06:47 PM
08/20/18 06:47 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I'll throw this out there. Same symptoms, adjusted the cable every way possible. My bran new shifter arm on the trans had loosened up even though the nut was securely where loctite'ed. I ugged it down as tight as I could get it from underneath, adjusted from N, and works perfectly.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2539310
08/20/18 10:59 PM
08/20/18 10:59 PM
Tulsa OK
Tulsa OK
Well, jacking with that cable bracket made everything work. It will start in park and neutral as well as hit all the gears. I guess I have been lucky in the past and just simply installing that bracket and tightening it down worked fine.
Re: Turbo Action Shifter, strange issue [Re: Bad340fish] #2539341
08/20/18 11:37 PM
08/20/18 11:37 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Just be careful and make sure its adjusted properly, I also was lucky the last 12 or so times I have had the trans out, time before last not so lucky. i broke a trans three days before the Bracket Finals last year, my very good friend / trans guy got it fixed and back to me in two days. I rushed got it back in and thought i had the shifter adjusted properly but it felt tight. I loaded the car left at five A.M. and drove 2 1/2 hours to Numidia. It still felt tight warming the car up for the first time shot. I staged left ok and when I hit second it fried the trans, it turns out that I had it so far out of adjustment that it broke the rod in the trans cutting off oil circulation thus frying the trans. I race all year to Qualify and my rushing cost me not only the trans but my chance to race at the Bracket Finals. My friend rebuilt it and when i put it back in I must have checked the shifter a dozen times to make sure it was right.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
