Re: hydraulic clutch conversion without a kit
[Re: earlymopar]
#2539024
08/20/18 01:57 PM
08/20/18 01:57 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
A 3/4" master should normally have a 7/8" bore slave. Then it's just a matter of FULLY bleeding the slave and adjusting everything correctly from the pedal to the clutch arm and cylinder positions. ... - EM EM, I see you've highlighted the FULLY bleed portion of your post. Are there any tricks to getting the last bits of air out of these hydraulic systems. I have one and I believe I may have a small amount of air stuck in it. I've tried power bleeding, but it still feels like I may have some trapped air.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: dusterbd13]
#2539036
08/20/18 02:15 PM
08/20/18 02:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The factory pulls a vacuum on them when they do a fill, Don't have to worry about bleeding out something that isn't there.
[Re: dusterbd13]
#2539099
08/20/18 03:49 PM
08/20/18 03:49 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you have a power brake booster, there isn't enough room to mount a clutch MC right next to the brake MC but, if you have standard brakes, the Wilwood MC can mount next to the brake MC.
[Re: dusterbd13]
#2539151
08/20/18 05:26 PM
08/20/18 05:26 PM
Supercuda
About to go away
About to go away
up yours
Take something like this https://autoplicity.com/5372270-ams-auto...ingComNOFITMENTadapt it to the stock pedal and make an adapter to match to the firewall. Remote the reservoir. Under $100 if you are handy.
[Re: dusterbd13]
#2539723
08/21/18 06:48 PM
08/21/18 06:48 PM
Supercuda
About to go away
About to go away
up yours
Stuff I linked, 88 Fiero application
Clutch master, 11/16" bore Clutch slave, 15/16"
4th Gen Camaro
Clutch master, 3/4" bore
Rockauto has the specs
[Re: Supercuda]
#2541504
08/26/18 11:37 AM
08/26/18 11:37 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
On this Bigblockdart link. Does the rod come out of the slave straight like a suspension shock absorber or is it free to swivel with a ball joint after the piston?
