Page 3 of 4 1 2 3 4
Re: Highway and 3.91's [Re: Mag162] #2537926
08/17/18 11:16 PM
08/17/18 11:16 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Not all of them do.
A firm wrist can handle a car as it was originally made, no modifications needed.
Re: Highway and 3.91's [Re: finn] #2537934
08/17/18 11:34 PM
08/17/18 11:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By finn
As to the limp wrist comment, why do you think all the performance cars have overdrive transmissions now?
Because all you limp wrists cried about the noise. whistling
Here's a clue. MoPar had OD trans in the 40's. Not like it's something new.
Don't be the exception.
Re: Highway and 3.91's [Re: Supercuda] #2537983
08/18/18 01:57 AM
08/18/18 01:57 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Thats a negatory there Ghostrider. Reduced RPM @ cruise equates to lowered emissions and improved mileage
every.
single.
time.
Overdrive has been enhanced with lockup convertors for the same reasons.
Re: Highway and 3.91's [Re: Mag162] #2537987
08/18/18 02:07 AM
08/18/18 02:07 AM
P
Porter67 Offline
Porter67  Offline
P
Ba.... Its all good if people like OD trans, obviously I like the old deep geared 1:1 stuff and I can drive slow until I need to drive fast and I could not give a --- about the cost of gas.
I live in the dry heat, if it hits 40% humidity im drippin so I do understand the ac part also.
One day I will give in, but I hope its not soon.
Re: Highway and 3.91's [Re: Mag162] #2537993
08/18/18 02:43 AM
08/18/18 02:43 AM
Kirkland, Washington
Pacnorthcuda Offline
Can't believe how little the 3.55-1 is mentioned here. In a thread about 3.91's.
In the days before OD, ALL ratios were a compromise in a car driven both in town and at speed.
The 3.55 (3.54 for you more fortunate folks) was/is a GREAT multi-purpose gear!
Re: Highway and 3.91's [Re: Mag162] #2537996
08/18/18 02:53 AM
08/18/18 02:53 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
so keep the stock 391 and trailer it?
5549 post on old board
Re: Highway and 3.91's [Re: Mag162] #2538017
08/18/18 08:07 AM
08/18/18 08:07 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Had a car for a while with 4.10:1 gears and 26" or so tires Also had no PB or PB but it did have 4 wheel drums,was my daily driver and went for carshows and such everywhere and the only thing i would have changed on that car if i had keept it would have been discbrakes in the front. Sure i wasnt going fast on the highway but no problem driving the posted limit even thought it was alitle hard on fuel on highways.
Re: Highway and 3.91's [Re: A990] #2538040
08/18/18 10:13 AM
08/18/18 10:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
every.
single.
time.
And not one limp wrist cried about worse mileage and emissions. The cried about "the engine screaming as you tootle along in the right lane getting passed".
Re: Highway and 3.91's [Re: Mag162] #2538047
08/18/18 11:11 AM
08/18/18 11:11 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Engines also wore out faster before overdrive.
The stock 318 in the D100 I mentioned before would not keep up with traffic with the pedal to the floor.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Highway and 3.91's [Re: Mag162] #2538049
08/18/18 11:18 AM
08/18/18 11:18 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My first 69 SuperBee had 3.91s back in '74 and 3.91s have been my go-to gears ever since. Even today, my Cuda has 3.91s. But now, it also has a 518. So blasting down the hiway at 75 or so is no big deal......for me or the car.
3.91s are a lot of fun but are very hard on the engine on the hiway. I have popped more than one big block screaming down the hiway. But that was back when these cars were disposable and I could go to the local wrecking yard and pick up another 440, swap my parts to it, and go beat on it some more.
Today, blocks and stuff are harder to find, more expensive, and I am older and lazier. So, no 3,000 or 4,000 RPM screaming down the hiway for my stuff anymore. It may take it.....for awhile. But there is no doubt that it is hard on the engine. And we have choices now that we didn't have then. We can enjoy 3.91s and have reasonable engine speed on the hiway. Kinda like having your cake and eating it, too.
It's 2018, not 1974.
Master, again and still
Re: Highway and 3.91's [Re: Soopernaut] #2538051
08/18/18 11:26 AM
08/18/18 11:26 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
lol, that wasn't it's job. Imagine that same ride with a /6. Wee.
As for wearing out faster, more likely it had to do with the rings used and the oil formulations than OD. I still have the 318 out of my 87 Diplomat, 200k+ miles, bores look pristine. Moly rings, good oils, regular maintenance. No OD. back in the musclecar days, well oils sucked and cast iron rings.
Re: Highway and 3.91's [Re: Mag162] #2538105
08/18/18 01:09 PM
08/18/18 01:09 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
If you are taking the time to ask then I believe you would be happier with 3:55. I had an E body with 440, 29.5" tall rear tires and 4:10s. I was not happy on the highway. Holding everyone up in the right lane.
Keep old mopars alive.
Re: Highway and 3.91's [Re: Mag162] #2538122
08/18/18 01:32 PM
08/18/18 01:32 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I have 3.54 gears in my pile,and was thinking about switching up to 4.10s for racing.
Will my wrists become any stronger?
If Passon could kick out those 5 speeds he could sell a bunch.
Re: Highway and 3.91's [Re: Mag162] #2538158
08/18/18 03:25 PM
08/18/18 03:25 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I ran 4.10's for years in my wagon with 28" tires. I finally had enough of slow lane cruising and the engine singing above 3k. I swapped in 3.55's and my only question was why didnt I do it sooner! It made driving everywhere much more enjoyable. Granted, it did also have a healthy BB stroker, so still plenty of tire roasting at will . But w the 3.55s, I could actually keep up with the majority of highway traffic for once, without buzzin the heck out of it. Prior to the 4.10s I had a Charger with 4.56's, and yes I see the pattern of gear ratio change with my age smile .
2 kids and a dog
Re: Highway and 3.91's [Re: Mag162] #2538165
08/18/18 03:57 PM
08/18/18 03:57 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
At hiway speed, the difference between 3.91s and 3.55s is a little over 300RPM. That isn't that big of a difference.
http://www.wallaceracing.com/calc-gear-tire-rpm-mph.php
Re: Highway and 3.91's [Re: Mag162] #2538181
08/18/18 05:04 PM
08/18/18 05:04 PM
BlueRacer69 Offline
BlueRacer69  Offline
Don't know if it's possible or not, but if the OP was able to run a tall tire on his Wagon, say 29 inch or better it mite not be to bad.
Re: Highway and 3.91's [Re: DaveRS23] #2538230
08/18/18 08:27 PM
08/18/18 08:27 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
That was my first thought. Approximately 10% difference. Not worth it in my opinion. There is no gear ratio available that will allow you to cruise at 1500-2000 RPM like you are used to in modern cars with 2 overdrives and lockup converters.
Back in the late 60's early 70's many muscle cars from Ford. GM. and Mopar came with 4.10 gears and 26" tires. However a 383 Fury Wagon was not then, is not now a muscle car. It probably had a 2.93 originally. People drive faster now than in 1967. with a 2.93 gear at 75 mph the RPM will be 3000 plus but with no tach and a quiet exhaust system who noticed? 3000 RPM is not going to hurt a 383 unless it is already hurt.
The way I see it a 2.93, much less a 3.55 will not get you were you want to be. Several people have suggested an overdrive transmission. That is the only way you are going to cruise at 70-80 MPH at comfortably low rpms.
ME? 4.30s with 28" tires. Has only been on the interstate longer than 10 minutes at a time once in 20 years. If I ever get around to switching to a Dana it will probably get a 4.10.
Re: Highway and 3.91's [Re: GomangoCuda] #2538258
08/18/18 10:02 PM
08/18/18 10:02 PM
IN
ahy Offline
ahy  Offline
IN
I ran a D200 PU back in the day. All over the place with a lot of highway miles. 4.10's and 29" tires. It did OK on the highway. I would cruise 70 and sometimes 75 max. It was probably turning 3300-3500 RPM on a sustained basis at higher speed. That is as much as I would want to run and even then noisy even with turbo mufflers.
With car size tires (25-26"?) I think 3.91 would be too much. Also speeds are higher now.
My current classic PU runs 4.10's and 31" tires. OK to 70-75 MPH and spinning pretty well at that speed. As much as I want.
My '70 Challenger ran a 318 and 3.23 as original with 24-25" tires. The original powertrain did surprisingly well. Decent acceleration and OK on the highway. Now runs a 496 and still 3.23 rear. Also OD transmission. It runs well.
If highway driving is part of your plan, I would suggest a 3.23 rear. It will do fine on the highway and the 383 should handle it fine at low speeds. Plenty of go.
Re: Highway and 3.91's [Re: Mag162] #2538324
08/19/18 12:17 AM
08/19/18 12:17 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Got 4.30's in my Charger and they're fine cruising around 70mph. People magically move over when I come up behind them for some reason. Still, in the next few years I'll build a 400 based stroker and swap in my 3.91 pig. I think that will do for anything less than a cross country tour. YMMV...….
Re: Highway and 3.91's [Re: Mag162] #2538406
08/19/18 01:52 AM
08/19/18 01:52 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Back in 68-70 my 64 Plm had 2.76 and a 4 speed (a little hard on the clutch) oval sprint track tires on 15 inch mag wheels, kinda tall and had to massage the well a little. Even at 80 mph it was still under 2000 rpm. Back in those days I knew where the radar traps sat so we went whatever mph we wanted. The 70 Z would run 3000 at 60 but I have no idea what gear it had, buzzed around the 95 interstate 3500-4000 or more all the time. To get a ticket one had to be real stupid, not like today.
Page 3 of 4 1 2 3 4
