Milodon 21815 Pump #2538010
08/18/18 07:06 AM
08/18/18 07:06 AM
new zealand
70wayfarer Offline OP
new zealand
i have seen this pump used with a melling hv cover. i have no experience with external pick up systems. do i even need one. engine is a 493 that will see regular strip time. max rpm would be around 7000. i have a 21815 pump available to me if i want it. can the melling hd shaft be used or do i need to buy the milodon 21503 shaft. beer
Re: Milodon 21815 Pump [Re: 70wayfarer] #2538023
08/18/18 08:59 AM
08/18/18 08:59 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
External pickup systems pull a lot more oil than an internal. Don't know if you absolutely need it, but would be good insurance. You will need a shaft with a hardened tip, and the Milodon pump requires a longer shaft than stock. The Melling cover should work fine. Check your clearances for your mounts, frame, steering gear.
[image][/image]
Re: Milodon 21815 Pump [Re: 70wayfarer] #2538137
08/18/18 02:20 PM
08/18/18 02:20 PM
I ran a street and strip motor(700+ HP) on Oregon pump gas for a lot of races and street miles with internal 3/8 pickup, OEM 6 quart Mopar 1970/71 440 six pack oil pan and a Mellings high volume oil pump with the bypass spring cut to give me 65 Lbs. oil pressure with hot oil at 6500 RPM. I had to use a Milidon bronze gear oil pump drive for the stock oil pump also due to using a solid roller cam up
I've ran both types of oil systems, single line , dual line and internal pickups with success shruggy
Re: Milodon 21815 Pump [Re: 70wayfarer] #2538198
08/18/18 06:24 PM
08/18/18 06:24 PM
new zealand
new zealand
i'm using a motor plate so clearance should be ok. some say to change up to external pick up, others have used 3/8 or 1/2 pick up and hv pump with good results.
i failed to get the pick up hole enlarged while at the machine shop, and short block is now assembled. that was why i was going to look at a external pick up. i'll look at the pump and do any necessary blending and run with the 3/8 pick up and 7 quart pan. cheers
Re: Milodon 21815 Pump [Re: 70wayfarer] #2538299
08/18/18 11:27 PM
08/18/18 11:27 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
That pump takes a bit longer shaft. I’ve ran one on my dart for several years with a normal cover. Worked real well, shifted my hemi at 7200 and the rod bearings could be reused.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Milodon 21815 Pump [Re: 70wayfarer] #2539365
08/21/18 12:20 AM
08/21/18 12:20 AM
gregsdart Offline
gregsdart  Offline
A good pump from what i hear, i am putting one in to gaurantee enough oil flow for loose clearance lifters and oil thru pushrods. Most race setups won't need it, and if it pulls a lot more volume than a melling hi volume, i wonder about cavitation if used with a stock 3/8 factory pickup. It also requires the. Milodon longer oul pump drive, 23 for rollercams, 03 for cast cams.
Re: Milodon 21815 Pump [Re: 70wayfarer] #2539467
08/21/18 10:29 AM
08/21/18 10:29 AM
an8sec70cuda Offline
If you can fit the external pickup system, then use it. No downsides IMO.
I've been running that same pump w/ a stock Melling pump cover on my 572" hemi for many years w/ no issues. I did "port" the cover to help the flow. I used to have the Milodon cover for a remote filter for a long time, but got tired of the extra plumbing and clutter, so I put on the normal cover and I'm much happier w/ it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Milodon 21815 Pump [Re: 70wayfarer] #2539559
08/21/18 01:38 PM
08/21/18 01:38 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Is this the pump you are referring to? I have the photo saved as 21814 though, and use a stock, ported cast cover on it to save room. I believe it is available with a side feed -12 fitting. It would work nicely with a stock cover as well.
It's supposed to take less power to drive due to the design change to the gearator. Internal oil pick-up passage enlarged to 1/2" and block passages massaged.
