354 and 392 Fuel Pump #2536623
08/15/18 10:00 AM
08/15/18 10:00 AM
Kentucky USA
RR6BBL1969 Offline OP
Kentucky USA
Is the fuel pump for the 354 and 392 Hemi the same? Is there a high volume pump needed for the 354 with a 2x4 setup? Or does one fuel pump work for either a single 4bbl. and a 2x4 bbl.?
Re: 354 and 392 Fuel Pump [Re: RR6BBL1969] #2536632
08/15/18 10:45 AM
08/15/18 10:45 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Same pump works for both engines, both carb setups. Originals are rebuild-able as well.
Re: 354 and 392 Fuel Pump [Re: ScottSmith_Harms] #2536966
08/16/18 12:13 AM
08/16/18 12:13 AM
Kentucky USA
Kentucky USA
Thanks Scott! Maybe I should just rebuild mine, it wasn't bad but has not been used in 10-20 years. Do you rebuild them? I bought an NOS fuel pump for my 1969 440 and it was very nice looking.....unfortunately it had shelf rot, no good.
Re: 354 and 392 Fuel Pump [Re: RR6BBL1969] #2537071
08/16/18 10:30 AM
08/16/18 10:30 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes I can rebuild them, as long as it is the style that screws together. Send me an email for details. scott@harmsauto.com
Re: 354 and 392 Fuel Pump [Re: RR6BBL1969] #2537400
08/16/18 10:18 PM
08/16/18 10:18 PM
Kentucky USA
Kentucky USA
rr6bbl1969@aol.com
yes , they have the screws. And I have two Carter 4 BBL's that need going through. They are the correct carbs for my 354 . I can get the list numbers if you need. Maybe you can work me a deal on all three?
