Re: Highway and 3.91's
[Re: Mag162]
#2536635
08/15/18 10:47 AM
08/15/18 10:47 AM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
How fast do you want to drive and for how long at a time?
Master, again and still
[Re: Mag162]
#2536707
08/15/18 12:52 PM
08/15/18 12:52 PM
Posts: 6,717 KY
65pacecar
KY
I have a 65 Plymouth Sport Fury 383 with 3.91 gears and it does fine on the highway. I prefer two or four lane roads but the interstate is OK too, you wont be holding at 100 mph for long stretches but cruising at 65-70 isn't bad. I wouldn't want to drive it from Miami to Seattle or anything though, that would be a long trip. I had 3.23 in it before, really prefer the 3.91 but I mostly drive around town and stuff.
[Re: Mag162]
#2536717
08/15/18 01:09 PM
08/15/18 01:09 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Having a taller tire will help when using the deeper gear.
...FAFO...
[Re: Mag162]
#2536721
08/15/18 01:12 PM
08/15/18 01:12 PM
Posts: 2,256 IL
furious70
IL
With a 28" tire it is ok on 2 lane roads, I personally hate it above 60-65. Fun around town yes
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Mag162]
#2536724
08/15/18 01:22 PM
08/15/18 01:22 PM
skicker
"The Champ"
"The Champ"
Western Md.
It's all a trade off. The 70 Satellite has 3.23's and 30" tires...Hate it around town but out on the freeway it doesn't even run good until 70 mph and up. The 69 Dart has 391's and 28" tires...much more fun around town but starts to turn more RPM's than I like above 60-65 mph. This new 72 Duster were putting together is 4.11's with 28" tires...should be even more fun but will I'll need to stay off the freeway with it...
...FAFO...
[Re: buildanother]
#2536729
08/15/18 01:32 PM
08/15/18 01:32 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Assuming you have not so tall tires, at 3000 rpm you will be in right lane with most folks passing you? Yep. I think with 275/60s/auto and 3.91s I was doing 65 at 3500 rpm. Too hard on the motor for any extended driving for me. Now, if you're talking a couple miles to get ice cream and back, you're probably ok.
[Re: Mag162]
#2536740
08/15/18 01:43 PM
08/15/18 01:43 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Put the in and have some fun. You can always swap your original gears set back in in a few hours before a long trip.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: buildanother]
#2536758
08/15/18 02:19 PM
08/15/18 02:19 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Assuming you have not so tall tires, at 3000 rpm you will be in right lane with most folks passing you? You'll be looking at the tach more than the speedo.
[Re: buildanother]
#2536793
08/15/18 03:55 PM
08/15/18 03:55 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Assuming you have not so tall tires, at 3000 rpm you will be in right lane with most folks passing you? This is what it was like in my 68 D100. 318, auto and 3.91 gears with 235/75/15s...
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: John_Kunkel]
#2536898
08/15/18 09:04 PM
08/15/18 09:04 PM
Posts: 4,748 Florida
BDW
Assuming you have not so tall tires, at 3000 rpm you will be in right lane with most folks passing you? You'll be looking at the tach more than the speedo. Exactly, I "only" have 3:73s and it sucked driving in the right lane at 3700rpm with every minivan passing you. 518 swap was the best thing I've done.
