Re: Need help tuning dominator for the street
[Re: polyspheric]
#2536733
08/15/18 01:36 PM
08/15/18 01:36 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
You might want to put a power valve in the front and jet down to 84 or so
What took everyone so long? Because it's a crutch for a blubbery mess 3 circuit and if Chip is happy with his that's good but you are one of damn near none........
[Re: Canam800]
#2536745
08/15/18 01:52 PM
08/15/18 01:52 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The spec sheet posted shows it has a pvcr, so the PV should function....... just make sure it has a vacuum port in the cavity.
I doubt the motor would run “well” at part throttle if you leaned it out far enough to hurt anything. Generally, big cam, big heads, big intake........ tuned so that it feels like it’s running pretty well at part throttle.........it’s usually still on the rich side.
[Re: Canam800]
#2536826
08/15/18 05:26 PM
08/15/18 05:26 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Mine has a PV on the primary side BTW. It is far from a blubbery mess.
Guess I'm the odd man out in this conversation...different observations about a couple different carbs I've had here.
[Re: Canam800]
#2536839
08/15/18 06:10 PM
08/15/18 06:10 PM
fast68plymouth
So. Burlington, Vt.
One thing at a time.
Just install the PV with like 85 jets and drive it...... see how it goes. Tweak from there.
The pre-HP 3 circuit 4500’s didn’t have an air bleed in the int circuit.... just a hole where one could go.
[Re: an8sec70cuda]
#2536851
08/15/18 06:40 PM
08/15/18 06:40 PM
Thumperdart
State of confusion
Guess I'm the odd man out in this conversation...different observations about a couple different carbs I've had here. Glad that works for you and apparently you got a good tune going............ Do you have a wide band to verify afr's at different engine speeds.......... Just asking to get info and understand how you verify that your 3-circuit is great on the street and has no blubbery or over rich issues cos if so, that's a good thing for sure just haven't seen it first hand..........
[Re: Canam800]
#2537087
08/16/18 11:17 AM
08/16/18 11:17 AM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Looks like you're not alone Chip The Dominator on my 572 Hemi is a Pro Systems 3 circuit as well. On the dyno with open headers, the AFRs from 4K and WOT up were perfect and the engine performed really well. I toyed with the idea of maybe going to a 2 circuit conversion but decided to have a go at dialling it in nicely in the car. I have dual Widebands - one in each collector, this helped a lot as a tuning guide. Once in the car the IABs and Int circuit needed a little tweaking along with equal reductions in jetting on both the Pri and Sec side - with a full exhaust now on the car, it really made a difference to the fuelling. The IFRs, HSABs and PVCR jet I left untouched so far. It has a 5.5 PV in front as well, I now have it idling hot at around low 15s and cruises hi 14s/low 15s as well. There is little to no real load at idle or part throttle and despite what others have told me, I'm letting the car tell me what it likes using AFRs as a guide. The car loves the current setup, no surging, great transition and super nice plugs and clean oil. Hell, if I keep the right foot out of it it ain't half bad on the benzene consumption lol. I'm now creeping up on the WOT and its nearly there but still a tad on the rich side need to get to the track to dial it in further. I'm guessing the PVCR jet will need to be a little smaller so I'll see what happens. In my case I had to be super patient and persistent, make one change at a time, document each change, drive it and see what the car/engine was telling me. A bit of work - for sure, Worth it ? ABSOLUTELY ! I've found most guys don't have the patience (or time) to take the time to understand each circuit and its effects and then to dial it in properly with the right tools/parts. Each engine is different ...gotta give it what it likes and use AFRs as a guide.
[Re: Canam800]
#2537105
08/16/18 12:06 PM
08/16/18 12:06 PM
Posts: 4,206 New York
polyspheric
New York
It's a debate. Who agrees with me on almost every product? Holley. Who does not? People in a "State of confusion".
Biggest reason to remove PV: you have no idea what it does.
Boffin Emeritus
[Re: LAD 524]
#2537165
08/16/18 01:55 PM
08/16/18 01:55 PM
Thumperdart
State of confusion
Looks like you're not alone Chip The Dominator on my 572 Hemi is a Pro Systems 3 circuit as well. On the dyno with open headers, the AFRs from 4K and WOT up were perfect and the engine performed really well. I toyed with the idea of maybe going to a 2 circuit conversion but decided to have a go at dialling it in nicely in the car. I have dual Widebands - one in each collector, this helped a lot as a tuning guide. Once in the car the IABs and Int circuit needed a little tweaking along with equal reductions in jetting on both the Pri and Sec side - with a full exhaust now on the car, it really made a difference to the fuelling. The IFRs, HSABs and PVCR jet I left untouched so far. It has a 5.5 PV in front as well, I now have it idling hot at around low 15s and cruises hi 14s/low 15s as well. There is little to no real load at idle or part throttle and despite what others have told me, I'm letting the car tell me what it likes using AFRs as a guide. The car loves the current setup, no surging, great transition and super nice plugs and clean oil. Hell, if I keep the right foot out of it it ain't half bad on the benzene consumption lol. I'm now creeping up on the WOT and its nearly there but still a tad on the rich side need to get to the track to dial it in further. I'm guessing the PVCR jet will need to be a little smaller so I'll see what happens. In my case I had to be super patient and persistent, make one change at a time, document each change, drive it and see what the car/engine was telling me. A bit of work - for sure, Worth it ? ABSOLUTELY ! I've found most guys don't have the patience (or time) to take the time to understand each circuit and its effects and then to dial it in properly with the right tools/parts. Each engine is different ...gotta give it what it likes and use AFRs as a guide. You're right about the patience part for sure and again, if YOU are happy that's all that matters but every single 2 circuit conversion is still that, a 2 and no one as far as I know has ever changed back to a 3. Forest on here went 8-flat at almost 171 mph with a 2 I converted for him and it's cleaner n meaner than ever and that's just ONE example......I also know the HEMI's have a different fuel demand than a wedge and like more fuel from my testing...........
[Re: Thumperdart]
#2538063
08/18/18 11:49 AM
08/18/18 11:49 AM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I was hanging out at the local speed shop yesterday while they were dynoing a fresh 540 shebby boat engine. The owner had them install Holley Dominator size multi port injection and they were trying to tune it.
Well, first they were just trying to get it to run well enough, long enough to start tuning. They were on their second day trying to get it lined out. They swapped a carb on to break it in and get some initial details.
They had tried about everything they knew to try, had called Holley several times and had switched back to the carb to make sure that the EFI was the problem.
I'ld hate to pay that bill. And did I mention that the boat had twin engines? So, they have this to do again. Anyone care to guess what the customer will have in his EFI when it's all said and done? $6,000? $8,000? Could it go $10,000?
Master, again and still
[Re: DaveRS23]
#2538068
08/18/18 12:05 PM
08/18/18 12:05 PM
Thumperdart
State of confusion
I'ld hate to pay that bill. And did I mention that the boat had twin engines? So, they have this to do again. Anyone care to guess what the customer will have in his EFI when it's all said and done? $6,000? $8,000? Could it go $10,000? Yep, I get those calls a lot and they see the light after all including the several I converted from corn to gas.........Kevin at CSU has a saying and in MOST cases I agree but I can't post it here but he's not a fan either..........EFI has it's place just never on my plate nor would I ever suggest it EVER.............
[Re: DaveRS23]
#2538092
08/18/18 12:44 PM
08/18/18 12:44 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
They should have called me. I could have remote connected and tuned The Holley EFI over the Internet. I'm doing two remote sessions like this every day. Unless there's a mechanical issue this works every time. efiexpert.com
[Re: Mopar_Rich]
#2538247
08/18/18 09:26 PM
08/18/18 09:26 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Why doesn't Holley tech recommend you in certain cases, Rich? Why does the customer have to figure out who to call when he's struggling with their product?
I will say that when they called the engine's owner, he suggested that they call Holley tech a couple of times to see if they could get a more competent tech. Apparently, this isn't his first experience with them.
