AC pulleys to non-AC pulleys? #2535447
08/13/18 02:55 AM
08/13/18 02:55 AM
State, country, etc.
gss Offline OP
gss  Offline OP
I'd like to lose the big iron high-mount alternator bracket and replace it with the non-AC triangle bracket. Am I correct in assuming the 4 sheave crank pulley and the fan pulley needs to go too? What about the power steering pulley?
Re: AC pulleys to non-AC pulleys? [Re: gss] #2535457
08/13/18 03:39 AM
08/13/18 03:39 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I had to get new water pump and crank pulley, also new power steering bracket.
Re: AC pulleys to non-AC pulleys? [Re: gss] #2535594
08/13/18 01:17 PM
08/13/18 01:17 PM
I would think that at least (1) of the 4 groove crank pulley grooves would line up for you & 440source has several thickness of pulley spacers, as you do want dead on alignment. Mockup & go from there.
