Another help me choose a cam thread 69 Charger 440 4spd 3.54
#2535415
08/13/18 01:20 AM
08/13/18 01:20 AM
Posts: 2,336 Ball Ground, Georgia
Dixie
Hey Guys,
Would like your opinion on a new cam for my car. The car is a '69 Charger, '69 440, 4-spd, 3.54 Dana, 295/50/15 tires. Engine is running factory carb, intake, 906 heads and exhaust manifolds with stock exhaust system with repro hemi mufflers. Compression is 11.26:1, heads cleaned up with larger exhaust valve. Other than that, pretty stock.
What I'm looking for is a cam that will enable the most performance from the engine given the restrictions of the stock carb, intake and exhaust. Also, being a big heavy car with a 4-spd. I don't care about how it sounds, just how it runs.
Looking for single bolt, hydraulic cam for stock rocker assy.
Thanks in advance for any suggestions!
Re: Another help me choose a cam thread 69 Charger 440 4spd 3.54
[Re: Dixie]
#2535426
08/13/18 01:47 AM
08/13/18 01:47 AM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
better get some race gas for that compression & iron heads
[Re: Dixie]
#2535429
08/13/18 01:51 AM
08/13/18 01:51 AM
Posts: 20,793 A collage of whims
topside
A collage of whims
Are you sure about that compression ratio? That's a lot for iron heads. If you were at 9.5:1 with iron, or 10.0 with aluminum, I'd say the Engle cam I put in my 446" 440 - 4speed, 3.55s, taller tire, '63 Savoy wagon - would be great. It was 224/234 @ .050, lift was around .504/.512, 110 CL. Well-behaved, nice street cam, not too rumpity, fine with 92 octane. That car ran Eddy heads and the full Maxie exhaust system, single 850 Holley, 10.0:1 actual CR. You can find the lobe specs at their website.
[Re: Dixie]
#2535521
08/13/18 11:03 AM
08/13/18 11:03 AM
Dixie
Yes, I run race gas in it. It's 11:26 compression.
[Re: Dixie]
#2535750
08/13/18 05:49 PM
08/13/18 05:49 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
.....Engine is running factory carb, intake, 906 heads and exhaust manifolds with stock exhaust system with repro hemi mufflers. Compression is 11.26:1, heads cleaned up with larger exhaust valve. Other than that, pretty stock.
..........hydraulic cam for stock rocker assy.
Your intake is by far your performance limiting factor. Will you be modifying it in anyway? Bob K. cam or something like the Crower 271 is what I would probably look at.
[Re: BSB67]
#2535904
08/13/18 11:11 PM
08/13/18 11:11 PM
Dixie
Your intake is by far your performance limiting factor. Will you be modifying it in anyway? Bob K. cam or something like the Crower 271 is what I would probably look at. I had not thought about modifying the intake. How do you mean, modify it? By Crower 271, do you mean the 32241? Thanks!
[Re: Dixie]
#2535977
08/14/18 01:26 AM
08/14/18 01:26 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
So you left everything pretty stock but bumped up the compression a bunch. You changed pistons for sure to do that, if you didn't, you don't have 11.26 comp.
But with that said, with all the stock parts you are using there are a bunch of cams you could use. With the biggest restrictions stock intake and exhaust and 906 heads id go with a cam around 238* @.050 around .500 lift on a 108LSA. Any bigger and she will feel like a dog around town.
If you did change your pistons and have a true 11.26 , im not sure I would go much bigger then that either, because of the stock manifolds and intake. If it were a automatic with a vert, I would say you could go a little bigger.
[Re: Dixie]
#2536171
08/14/18 02:18 PM
08/14/18 02:18 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That’s what I was thinking.
I did a bunch of testing on that stuff 8-10 years ago. As Russ said, the stock intake is really a cork.
Stock 906 head @.500 lift = 226cfm Bolt on stock intake manifold = 189cfm Mild clean up stock intake = 195cfm Mild clean up 6bbl intake = 217cfm
Mild ported 346 head @.500 lift = 259cfm With stock intake = 202cfm Mild clean up stock intake = 212cfm Mild clean up 6bbl intake = 242cfm Gasket matched RB M1 single plane = 255cfm
The stock head with the cleaned up 6bbl intake outflows the ported head with the cleaned up 4bbl intake.
[Re: Sport440]
#2536197
08/14/18 03:05 PM
08/14/18 03:05 PM
Dixie
If you did change your pistons and have a true 11.26 , im not sure I would go much bigger then that either, because of the stock manifolds and intake. If it were a automatic with a vert, I would say you could go a little bigger. Yes, long story short, after replacing pistons, decking block, surfacing heads, the engine builder used a thin head gasket and that's what the compression wound up at. It's had the heads cleaned up with mild porting. It is already assembled, but needs a new cam due to cam bearings not being installed correctly resulting in oil starvation. So, this is not a new rebuild. I'm keeping it stock externally. I don't know that the cam that was in it previously was the right choice given the engines restrictions, so just wondering what your recommendations are. Thanks for all the input!!
[Re: lewtot184]
#2536200
08/14/18 03:10 PM
08/14/18 03:10 PM
Dixie
I think you could run a little extra duration with that compression but i'd spread the lobe separation a little too. Could you give me an example of what you think would work? Thanks!
