440 Intake gaskets which ones ?
#2535101
08/12/18 03:19 PM
08/12/18 03:19 PM
Posts: 53 Connnecticut
acesneights
Connnecticut
I am swapping from a cast iron intake to an Edelbrock performer intake on my 76 Dodge Travco. I did this once before on another one but can't remember. Do I just use a new valley pan only or use the additional intake gaskets that appear to go on inside and outside of the valley pan at the intake ports ? I have both here just don't remember. I would like to block the heat riser from the intake side of heads as I have had issues of the gas boiling which is why I am doing the swap. It solved this problem on my last Travco. Thanks.
1975 Dodge Travco 440 BB
1972 Dodge Travco 318 SB
Re: 440 Intake gaskets which ones ?
[Re: acesneights]
#2535110
08/12/18 03:33 PM
08/12/18 03:33 PM
acesneights
Connnecticut
Just about ready to pull intake.
[Re: acesneights]
#2535132
08/12/18 04:22 PM
08/12/18 04:22 PM
acesneights
Connnecticut
These are the supplemental fiber gaskets. It did not have them with the cast intake.
[Re: acesneights]
#2535141
08/12/18 04:45 PM
08/12/18 04:45 PM
acesneights
Connnecticut
Well, I goofed with these gaskets anyway. I should have gotten Felpro #1214 which blocks the crossover ao I am sut down for a few days now while I order it. 😔
[Re: acesneights]
#2535152
08/12/18 04:57 PM
08/12/18 04:57 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
The fiber gaskets are normally not used unless the intake has been milled to accept them. I spray the valley pan with a red spray gasket sealer and a little rtv in the corners where the head gaskets are.
There are other ways to plug the heat crossover. I normally take some 1/4 aluminum, contour it and knock it into the intake.
[Re: stumpy]
#2535159
08/12/18 05:25 PM
08/12/18 05:25 PM
acesneights
Connnecticut
Ok thx. Yes stock heads. I also ordered ARP 144-2101 bolts for the intake as 3 of the old bolts the heads rounded out.
[Re: markz528]
#2535161
08/12/18 05:26 PM
08/12/18 05:26 PM
acesneights
Connnecticut
I actually read somewhere else too about packing it with fuenace cement. I need new i take bolts as well so the new gasket will arrive at the same time. Thank you for the help. I will use the red spray sealer and no paper..
[Re: scratchnfotraction]
#2536168
08/14/18 02:16 PM
08/14/18 02:16 PM
RapidRobert
I would use the paper gaskets with permatex "high tack" the thin red spray gasket cement (tho the last couple of cans of it had specs of dried red material/something in the spray) if your bolt holes will still line up. People have used the valley pans as is as did Ma with no issues but vac leaks are the cats' a$$ to deal with. I would check that the mating surfaces on the performer are straight. As said there are several ways to block the crossover & I would without a doubt avoid E10 gas if you have a choice in your location. I think superformance has thin (.015") side gaskets available but you are already duplicating parts but the more info available the better. EDIT & iirc 440source (on the thin .015" gaskets)
