Rallye dash voltmeter #2534770
08/11/18 09:37 PM
08/11/18 09:37 PM
70duster340 Offline OP
I have done some research, but have not found anything. I have a 1970 rallye dash, and would like to replace the ammeter with a voltmeter. Has this been done before, and if so, what was done to accomplish this?
Re: Rallye dash voltmeter [Re: 70duster340] #2534800
08/11/18 10:29 PM
08/11/18 10:29 PM
Andrewh Offline
Andrewh  Offline
I do not know about a rally dash.
what people did was find a similar size sun meter volt meter and disassembled the gauge.
depending on how close you want it to look, some took apart the old one and used that face plate on the sweep portion of the sun meter gauge so it would still look the same.
others found a place that could replicate the font and repainted/stickered over the old so it showed correct voltage with the old gauge face but new gauge guts.
you would have to see, and I am guess a more rounded sweep, might be an issue.
Re: Rallye dash voltmeter [Re: 70duster340] #2534805
08/11/18 10:34 PM
08/11/18 10:34 PM
I would prefer to have numbers instead of the OEM faceplate. Is this something that can be done on a printer?
I did find a picture of this being done on a standard gauge cluster, but nothing on a Rallye dash.
Re: Rallye dash voltmeter [Re: 70duster340] #2534831
08/11/18 11:17 PM
08/11/18 11:17 PM
BDW Offline
BDW  Offline
Redline Gauges can convert the ammeter to voltage.
Re: Rallye dash voltmeter [Re: 70duster340] #2534834
08/11/18 11:20 PM
08/11/18 11:20 PM
Andrewh Offline
Andrewh  Offline
http://oldschool.mrheaterbox.com/premiumdashdecals.com/do_it_yourself.htm
This place sells decals. You might see if they can print one.
Re: Rallye dash voltmeter [Re: BDW] #2534882
08/12/18 01:07 AM
08/12/18 01:07 AM
Thanks. However, I have researched the Redline thing and it seems quite expensive.
Re: Rallye dash voltmeter [Re: 70duster340] #2534934
08/12/18 04:52 AM
08/12/18 04:52 AM
WA
tman Offline
tman  Offline
WA
Re: Rallye dash voltmeter [Re: 70duster340] #2535156
08/12/18 05:17 PM
08/12/18 05:17 PM
Very good, sir. Thank you!
Re: Rallye dash voltmeter [Re: 70duster340] #2536334
08/14/18 06:43 PM
08/14/18 06:43 PM
Anyone have any idea if this will work? It's a 1.5 inch Auto Gage voltmeter that I already have.
Re: Rallye dash voltmeter [Re: 70duster340] #2536403
08/14/18 08:43 PM
08/14/18 08:43 PM
Andrewh Offline
Andrewh  Offline
you would have to measure the posts on the back and see if they are the same distance.
I think the post I Read about it, mentioned insulation being an issue.
The old posts fit through something that insulated and the new ones were short.
I don't remember what he finally insulated it with.
Re: Rallye dash voltmeter [Re: 70duster340] #2537021
08/16/18 03:33 AM
08/16/18 03:33 AM
OK thanks
