68-70 b body accel pedal and bright switch mounting holes ? #2532310
08/06/18 03:23 PM
08/06/18 03:23 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
Need to confirm location for bright HL switch mounting and accel pedal mounting on floor board. Have a new DS floor pan and no holes to mount either of these items. Dimensions or pictures would be awesome. Thanks in advance! Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 68-70 b body accel pedal and bright switch mounting holes ? [Re: 70gtx440dana] #2534096
08/10/18 10:46 AM
08/10/18 10:46 AM
Lansing, MI
Lansing, MI
BTT - Hoping someone can help with the accel pedal mounting hole locations. I am good on the bright switch.
Re: 68-70 b body accel pedal and bright switch mounting holes ? [Re: 70gtx440dana] #2534851
08/11/18 11:57 PM
08/11/18 11:57 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
I have to drill new holes in my new floor pan as well.
What I am planning on doing is to fit the carpet in then cut out the square for the petal base in the front right corner of the heel pad, then drill the holes.
If you drill the holes first, and they are off, you have to force the carpet around the hump.
Re: 68-70 b body accel pedal and bright switch mounting holes ? [Re: 1970GTX] #2535894
08/13/18 10:39 PM
08/13/18 10:39 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Here you go from my 1968 Superbee.
68 coronet gas pedal holes (2).jpg68 coronet gas pedal holes (3).jpg68 coronet gas pedal holes.jpg68 coronet high beam switch holes (2).jpg
Re: 68-70 b body accel pedal and bright switch mounting holes ? [Re: 70gtx440dana] #2535902
08/13/18 11:08 PM
08/13/18 11:08 PM
Lansing, MI
Lansing, MI
LTLBEE.....awesome info. I greatly appreciate it. Joe
