need corner weight advice for new 4 link car #2533887
08/09/18 06:23 PM
08/09/18 06:23 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, I am finally just about ready to bring my 31 plymouth coupe to its first test & tune ever at the drag strip. This is a new build, intended for Drag Week 2018 this September, and it is my first 4 link/coil over car ever.
Here are the specs as best as I can figure:
weight about 2700 with driver
flywheel horse around 675
t-56 magnum manual trans
mcleod soft lock clutch
4 link rear with afco double adjustable coil overs and a sway bar
straight axle in front with hair pins and afco double adjustable coil overs
30x13.5-15 MT ET streets
9" with 4.20 gears
How should I dial in the corner weights? WIth my small tire leaf spring stuff, I always made the right rear and left front heavy, and the left rear and right front light. I have heard that you don't do that with 4 link, but I'm not sure. Can anyone please point me in the right direction on this? THanks,
Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2533898
08/09/18 06:48 PM
08/09/18 06:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depend on how stiff the car is.. but I would
start with 10#-15# heavy on the RR.. my P-BODY
has 10# heavy on the RR at 2400# track weight..
if the car pulls right ADD more weight
wave
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2533907
08/09/18 07:15 PM
08/09/18 07:15 PM
Washington
madscientist Offline
Washington
9" with 4.20 gears
Joel
Ok, there is no like button but that thing is bad assed cool. Hemi, stick and Drag Week. Doesn't get any better than that.
Nice build.
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2533915
08/09/18 07:42 PM
08/09/18 07:42 PM
Minnesota
Minnesota
THanks!
Mr.P. it's pretty stiff. THe frame is boxed and it has a cage.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2533937
08/09/18 09:00 PM
08/09/18 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have a rear anti sway bar you wont need
much in the line of adding for the 4-link if
its stiff
wave
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2533969
08/09/18 10:16 PM
08/09/18 10:16 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Set it where JT told you to set it... you can't think of a 4 link like a leaf spring car.
69 GTX 68 Road Runner
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534038
08/10/18 01:57 AM
08/10/18 01:57 AM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
Great job, way awesome car.
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534069
08/10/18 07:20 AM
08/10/18 07:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I want that car.
Doug
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534071
08/10/18 07:46 AM
08/10/18 07:46 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Nice to see you finished the car Joel!
Google Billy Shops, old Ramcharger engineer, look at his "Traction Dyno". You need 4 scales and a chain and a come-along.
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534132
08/10/18 12:25 PM
08/10/18 12:25 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would start neutral and see what it does.
2011 Drag Pak Challenger
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534140
08/10/18 12:46 PM
08/10/18 12:46 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
That car is so cool i had to turn off the air conditioner here.
Get it on the scales, swaw bar disconnected on one side, get stance/ ride height as desired.
As light as the car is, start with the rear neutral. Adjust the swaybar to freely slide the link bolt in and out.
You should be able to control any induced steer with the shocks.
Re: need corner weight advice for new 4 link car [Re: rickseeman] #2534145
08/10/18 12:49 PM
08/10/18 12:49 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I agree, once the pinion angle is set with the upper Driver side bar, install the upper Passenger side bar neutral. Then if you need a touch of preload the the car will tell you by the way it wants to go leaving the line...
Re: need corner weight advice for new 4 link car [Re: quickd100] #2534265
08/10/18 04:30 PM
08/10/18 04:30 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Reading that makes me want to get a set of 4 corner scales, although I can't really weight jack a coil spring front end.
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534298
08/10/18 05:44 PM
08/10/18 05:44 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
You can adjust your 4-link bars and move weight around to get near equal weight on the rear tires on launch.
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534584
08/11/18 02:17 PM
08/11/18 02:17 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
A good starting point is for the LF + RR to equal 52% of total car weight with the driver in the seat.
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534715
08/11/18 07:04 PM
08/11/18 07:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Make sure when you install the bars they have no preload and if you have an anti roll make sure it is not loading the bars either. Also make sure you have your weight in the seat and all 4 tires aired up to the where they will be on track and fuel in it. Race ready in otherwords, just tossing that out there as sometimes people forget and even a couple pounds of air can make things change a fair amount.
As for the weight on the scales just install everything neutral and see where you are at. Not a ton of power and your weight and how the car was built will dictate those numbers as much as anything. I might likely run it that way as well unless it was totally out in left field corner weight wise. If the car goes straight then you are golden. If not adjust accordingly depending on what it is doing. Adding preload or taking it away depending on which way it is leaving. In general as power levels go up you will want more weight on the LR corner of the car. A lot of factors and generalizations but hopefully you get the gist of it.
Re: need corner weight advice for new 4 link car [Re: Hemi_Joel] #2534744
08/11/18 08:11 PM
08/11/18 08:11 PM
Minnesota
Minnesota
Thanks for all the great advise, it will all be considered. You guys are very helpful!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
