Re: gas tank finish
[Re: mopars4ever]
#2533280
08/08/18 02:15 PM
08/08/18 02:15 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
That looks fine to me. If I wanted to refinish it I'd use ZRC Cold Galvanizing Compound. I suspect, but don't know, when new, the tanks were formed from electro galvanized sheet metal.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
Re: gas tank finish
[Re: mopars4ever]
#2533397
08/08/18 06:02 PM
08/08/18 06:02 PM
Posts: 6,717 KY
65pacecar
KY
If you have to paint it Import Magnesium Engine Paint works pretty well and close the original color and sheen of the factory finish.
Re: gas tank finish
[Re: mopars4ever]
#2533582
08/09/18 01:46 AM
08/09/18 01:46 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Metal gas tanks before 2012 were made of terne sheet, which is basically solder coated steel sheet. At the steel mill, the steel sheet was hot dipped in terne alloy, 10-20% tin and the remainder lead. Nowadays terne sheet is steel sheet coated with all tin, no lead. This might look slightly different from the old kind with lead, but not much. The most obvious appearance difference in old and new tanks is new tanks are shiny and old tanks are dull from age, just as old solder or old lead turns dull from atmospheric corrosion. When cars from the muscle era were new, their tanks were shiny, just like new solder is shiny. If counting off for new tanks just because they are shiny, I would reconsider, because when the old tanks were new, they were shiny also. In other words, what might be considered an "original" finish on an old tank is not original at all - it's a different finish from original because it has aged and turned dull. Solder is usually roughly half tin, half lead, but repairs to old tanks can be made with solder. See: https://en.wikipedia.org/wiki/Terne
Re: gas tank finish
[Re: kentj340]
#2533595
08/09/18 03:18 AM
08/09/18 03:18 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Metal gas tanks before 2012 were made of terne sheet, which is basically solder coated steel sheet. At the steel mill, the steel sheet was hot dipped in terne alloy, 10-20% tin and the remainder lead. Nowadays terne sheet is steel sheet coated with all tin, no lead. This might look slightly different from the old kind with lead, but not much. The most obvious appearance difference in old and new tanks is new tanks are shiny and old tanks are dull from age, just as old solder or old lead turns dull from atmospheric corrosion. When cars from the muscle era were new, their tanks were shiny, just like new solder is shiny. If counting off for new tanks just because they are shiny, I would reconsider, because when the old tanks were new, they were shiny also. In other words, what might be considered an "original" finish on an old tank is not original at all - it's a different finish from original because it has aged and turned dull. Solder is usually roughly half tin, half lead, but repairs to old tanks can be made with solder. See: https://en.wikipedia.org/wiki/Terne You are correct. As of a couple years ago you could still source Terne out of Japan. The lead time is at least 6 months and you need to buy a lot. There is no paint that I know of that will look like it.
Re: gas tank finish
[Re: mopars4ever]
#2533650
08/09/18 10:32 AM
08/09/18 10:32 AM
Posts: 13,608 md
mopars4ever
md
There is no paint that I know of that will look like it. I`m finding that out from what I have seen.
