porting burrs: which ones/where to get em
#2533123
08/08/18 01:24 AM
08/08/18 01:24 AM
RapidRobert
I have some alum and iron/steel to do. Any tips on making em last/which types for alum/which for iron/steel. Thank you for your time.
Re: porting burrs: which ones/where to get em
[Re: RapidRobert]
#2533137
08/08/18 01:58 AM
08/08/18 01:58 AM
Posts: 20,674 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
My brother gets his from a couple tool places in town, but he has been chasing them for years as the places either stop stocking them, or go out of business. He spins the cutting ends in some sort of wax stick to keep the aluminum from clogging up the bits. I don't think cast iron sticks to them. Summit Racing sells them. https://www.summitracing.com/search?Sort...=porting%20bits
[Re: Neil]
#2533142
08/08/18 02:25 AM
08/08/18 02:25 AM
RapidRobert
they do have a bunch of em & I do have a candle I got to wick into stuck NPT fittings so I can also use it for the burrs.
[Re: RapidRobert]
#2533182
08/08/18 10:15 AM
08/08/18 10:15 AM
crabman173
crabman173
for aluminum just dip burr in ATF fluid every minute or so works great get burrs with long shafts then cut shafts to length you really need for your heads and what you are doing
[Re: ]
#2533263
08/08/18 01:17 PM
08/08/18 01:17 PM
RapidRobert
Good info/noted/just what I was after/thanks guys!
[Re: dogdays]
#2533327
08/08/18 03:45 PM
08/08/18 03:45 PM
crabman173
crabman173
Here is good tip for cheapo grinder $20 straight grinder from Harbor Freight--add length of pipe for $1.50 from hardware store now you have a decent long grinder you can control with both hands like the pros Cheap and it works like a dream
[Re: ]
#2533693
08/09/18 12:29 PM
08/09/18 12:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have 2 set ups for doing heads.. one is a electric die grinder with a variable speed controller and a air powered one.. I like to keep both set ups light(hours at a time does get tiring on the hands).. I have about 25 burs for different jobs.. alum heads I use the course burs and tootsie rolls.. iron I use the finer burs.. I spray WD40 on the iron burs and bees wax on the alum burs.. I like the 1 1/2" long burs for most of my work.. I have 1.5", 3", 6" and 1 12" long burs the short ones are easier to control.. dont let the burs get hot(thats usually a dull bur or its loaded up)
[Re: MR_P_BODY]
#2533697
08/09/18 12:35 PM
08/09/18 12:35 PM
RapidRobert
Good info & I have a straight grinder that I can certainly add a length of NPT pipe to, for better control/leverage. I'm assuming (like anything else) that quality (more $$$) burrs will last much longer than the pkgs of 4-6 I see on eBay (made in china I would assume).
[Re: MR_P_BODY]
#2533715
08/09/18 12:56 PM
08/09/18 12:56 PM
RapidRobert
Mr P I will take your advice
[Re: RapidRobert]
#2533748
08/09/18 01:39 PM
08/09/18 01:39 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't get wrapped up in the single cut burrs for aluminum, double cut burrs for cast iron BS. Single cuts burrs dig and bounce and if used especially by someone inexperienced become dull quickly and if its a long shaft, BEND. I use a foot controller to control my grinder speed and when done with a double cut burr doesn't even need sanding rolls to clean up. Bottom line is we aren't doing it for a customer to push out the door so "slow down" Porting tools 005_zpsjgwy0cgl by John Cadamore, on Flickr Porting tools 002_zps56hn5i69 by John Cadamore, on Flickr Porting tools 004_zpslw8s6tvt by John Cadamore, on Flickr
[Re: BradH]
#2533942
08/09/18 09:16 PM
08/09/18 09:16 PM
RapidRobert
OK, double cut burrs it will be & go slow. Brad those are some good prices.
[Re: RapidRobert]
#2534211
08/10/18 03:00 PM
08/10/18 03:00 PM
BradH
OK, double cut burrs it will be & go slow. Brad those are some good prices. Decent prices and a pretty good selection of sizes, shapes and cutter styles. I picked up some high-helix cutters to try out the last time I bought stuff. They kind of split the difference between the full aluma-cut and single/double-cut style that's more suited to iron & steel. You can use single/double-cut on aluminum, but absolutely must use grinder's grease (like a wax stick) or some type of fluid that helps resist the clogging issue. Also, keep a stiff wire brush handy to reduce the buildup before re-treating the cutter regularly during use. I used to get my carbides from the Mondello Technical School before ol' Joe passed away. I don't know what they even sell any more, if anything, since then.
[Re: RapidRobert]
#2534219
08/10/18 03:14 PM
08/10/18 03:14 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I used to get my carbides from the Mondello Technical School before ol' Joe passed away. I don't know what they even sell any more, if anything, since then. https://mondelloperformance.com/
