ceramic coat manifolds #2532668
08/07/18 08:36 AM
08/07/18 08:36 AM
ny
marcjames Offline OP
ny
I would like to coat my 67 hp exhaust manifolds is there a company that does this has any one done this diy thanks
Re: ceramic coat manifolds [Re: marcjames] #2532713
08/07/18 11:13 AM
08/07/18 11:13 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: ceramic coat manifolds [Re: marcjames] #2532821
08/07/18 03:09 PM
08/07/18 03:09 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I've done it here locally at a place called Pro-Kote. it's ok but I don't think it lasts as well as when applied to tubing.
Re: ceramic coat manifolds [Re: marcjames] #2532835
08/07/18 03:49 PM
08/07/18 03:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
http://www.centralctcoatings.com/
They recently did my headers $200 less then jet hot!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: ceramic coat manifolds [Re: marcjames] #2532842
08/07/18 03:58 PM
08/07/18 03:58 PM
MA
steve70 Offline
steve70  Offline
MA
I used Airborn Coatings in NC and was very happy with the results.
http://www.jetcoat.com/
1970 Challenger T/A 4 speed
Re: ceramic coat manifolds [Re: marcjames] #2533437
08/08/18 07:26 PM
08/08/18 07:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Are you guys doing this mainly for looks, or does it improve under hood temps?
Re: ceramic coat manifolds [Re: mgoblue9798] #2533646
08/09/18 10:24 AM
08/09/18 10:24 AM
an8sec70cuda Offline
The ceramic coating will help keep the underhood temps cooler..atleast on headers it does.
I had a set of 340 manifolds done in a high temp powder coat that my local powder coater uses. They look great and they claim it holds up on manifolds...headers not so much due to them being thinner and getting hotter.
I wanted this done for looks mainly. Cast iron manifolds w/o anything on them look like crap after a while. This should last a long time and look good. I've never been happy w/ any of the spray can type of manifold treatment.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: ceramic coat manifolds [Re: an8sec70cuda] #2533790
08/09/18 02:57 PM
08/09/18 02:57 PM
dogdays Offline
dogdays  Offline
There seem to be powder coaters on every street corner, you can look in the Yellow Pages.
30 years ago I wanted to coat my Mercedes exhaust manifolds and I sent them to West Coast Porcelain in South ElMonte, CA.
They came back black and shiny.
Only problem is that the first time I stated the engine and then let it cool down, tiny cracks appeared all over the surface. Years later, the porcelain is still there, as are the cracks.
Now, with epoxy coatings the material seems to have enough give to deal with the thermal expansion.
R.
Re: ceramic coat manifolds [Re: marcjames] #2534064
08/10/18 06:26 AM
08/10/18 06:26 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Used these guys on my stainless Viper headers 20 years back. They still look good.
http://www.headercoatings.com/
