Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2534020
08/10/18 12:46 AM
08/10/18 12:46 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, we torque the lugnuts on the drag cars and vintage TransAm cars to 75-80 ft/lbs. Zero problems ever, and the TA cars certainly put that stuff to the test. Not debating new street car lug nut torques, I've heard some pretty big #s like Stumpy says.
I'd take a look at how the studs meet the back face of the wheel and the interface between wheel/drum.
I'm curious about the problem, please report back with an update.
Re: Crager Wheel lug nuts loosening [Re: Paul_Fancsali] #2535486
08/13/18 08:54 AM
08/13/18 08:54 AM
Walton, Indiana
TimS Offline
TimS  Offline
Walton, Indiana
I've ran SB drilled (not unilug) Cragars on my Formula S for about 2 years. I installed long studs all the way around and used a drill press to drill the centers out of the recommended lug nuts for these. After having multiple issues with unilug BB Cragars I won't buy another set of those as I have torqued those to 75 ft/lbs as I did my Formula S SB. The unilugs seem to eventually get/come loose.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
